Norfolk bits + pieces (1 Viewer)
poppys
165
40
Norfolk
Since 1974 on and off
Ive recently moved to Norfolk ,15 miles Southeast of Norwich.Can anyone recommend somewhere I can buy small bits + pieces for my van.I'm looking to fit an outside gas connection so that I can run my BBQ off of the vans supply.With the right fittings I should be able to do this having worked for British Gas for 12 years in the past.
Apr 20, 2009
226
134
norfolk
Hi not sure where u are but the best and largest overall stockists of bits and pieces is in blowfeild .Norwich camping and leisure post code is NR13 4LQ
hope this helps
Jaws
23,836
72,460
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I have found that since Norwich Camping was taken over a couple of years ago they seem to cater less and less for motorhomes and to a certain extent tuggers
If you have no luck at Blowfield I would try Stowmarket Caravans. If you are around the Scole area it is 6 of one and half a dozen of tother as far as distance goes ( In fact Stowmarket is probably an easier drive ! )
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Easy just order from me and get Funsters disciount ::bigsmile: here >> http://www.johnscross.co.uk/categories/Gas-Appliances/Gas-Outlet-Points/
Peter
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Hi POPPYS . We got our van from Greentrees in Dereham and also there is Simpsons in Great yarmouth.. Both have good bits and bobs shops.. Good luck..
.Jenny and Mitch..
