Noisy Turbovent
Discussion in 'Motorhome Chat' started by oldun, Jul 28, 2010.
  1. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    I have a small 28cm fan assisted roof vent, similar to the link below, fitted to my motorhome.
    http://www.leisureshopdirect.com/ca...urbo_Vent_28_Rooflight_12v_White.aspx?aff=122
    The vent works well and shifts a lot of air.
    The main problem is that the noise level is far too high and becomes a real nuisance.
    I would like to reduce the noise level by reducing the speed.
    I could do this (I believe) by fitting a series resistance either permanently of withe the possibility of switching it out.
    Anyone had any experience with this modification and can offer advice?
  2. hilldweller
    Dec 5, 2008
    27,253
    26,254
    Macclesfield
    You want to be searching for a DC motor speed controller.
    Maplin or ebay.
    I'd take a guess at 5 or 10 amps rating, you should measure this.
  3. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    All the turbovents I've seen had speed adjustment built in, either by variable resistor or by three position switch. doesn't mean I've seen all the variations of course:Doh:.
    D.
  4. oldun
    Mar 23, 2008
    748
    160
    St Neots
    I do not have the large and expensive turbovent. I have a small 28cm opening with a small crude fan attached inside and it has only a two position switch - air in or air out.
    It's great to use when not inside the van - otherwise it does the job but very noisily.
    It takes 1.95 amps when running steadily. At start up the digital meter shows about 2.5 amps so the start up current will be in excess of this.
    I will now search Maplins for a controller.
    Thanks to you both.
    PS Dave has fitted most of the bits and pieces I have had fitted to my van - the turbovent I did myself. That first hole through the roof was pure torture!
  5. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    if you have no joy with a controller you could get a heater blower resistor block from a breakers yard for a few quid :thumb::thumb:
Similar Threads
  1. Sarahbrightvan
    20
    649
