Noisy Pump and Waste Water
Discussion in 'Tech/Mech General' started by saxon, May 22, 2008.
  1. saxon
    saxon Read Only Funster
    May 22, 2008
    60
    Cheshire
    Just bought our first motorhome - Mclouis Tandy 670 - 3 years old. Haven't got a clue about anything. The owner's handbook fails to explain where the second battery is located; when we turn the pump on it makes a noise - is this normal?
    We've found the fuses and the fresh water tank, but how do we locate the waste water tank and empty it? It is sooooooooo different from a caravan. Any help or advice would be greatly appreciated
    Regards
    Novice saxon
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,687
    78,944
    Sutton on Sea
    Hi Saxon, Yes motorhomes differ considerably from caravans in some ways, but in others they are almost the same.
    Your water pump might just be a noisy one, some are better than others in that regard, however it could have some air in the the system, this can make it noisy, try running all the taps, hot and cold and see what happens, also look at the pump mounting, this can be a source of noise and many people pad their pump to dampen vibrations.
    You wast water tank will emptied by an external drain tap, get under the motorhome and you will probably see it. Any other questions, just jump in and ask.
    Oh and Welcome to the forum. :thumb:
  3. RuthRv
    RuthRv Read Only Funster
    Jan 4, 2008
    869
    welcome to the fun saxon, don;t worry most of us have to ask ?s and you are on the forum where someone will be able to help you, we have some knowledgeable people on here,:Smile: but sadly not me:Rofl1: this is him indoors job remit:Rofl1:
    my job is to ensure that supplies of beer,wine, food, are plentiful:BigGrin:
    ruth
  4. highwayman
    highwayman Funster Life Member
    Jul 31, 2007
    858
    476
    Kent coast
    Hello and :welcome:
    You may fine your leisure battery under the drivers seat, that's the most common place.
    Your water pump will run till the water's up to pressure within the pipework then stop till the pressure drops ie tap turned-on.
    As for the waste tank, it could be anywhere underneath and may have a tap to open the drain or as my friend has a handle to pull under the rear bumper.
    So basically wait for daylight and have a good search-up :thumb:
    regards...nige
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    welcome saxon,
    if your pump is making a ticking/clicking noise when the taps are on it's working ok.
    if it makes the same noise when the taps are off, it's got a fault. take back to dealers.
    john
  6. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Saxon and welcome
    Lindy C on the forum sells a kit for silencing water pumps usualy for american rv's but i don't see why it wouldn't work on a Euro m/home
    might be worth giving her a shout :thumb:
  7. playbyte
    playbyte xMember
    May 4, 2008
    36
    Kirton-in-Lindsey
    Hi Saxon.
    I too am a Mclouis owner (281 4 years old) and have experienced similar noise from the water pump. However ours only makes the noise when it is charging the water system and then when you draw any water off. As a previous member has said there may be air in the system which is released by turning on all the taps until you get a full flow of water. This will reduce the amount of water in the tank of course and you can check this by looking removing one of the seat cushions and lifting the wooden board for access.
    The second battery, or leisure battery, on our motorhome is found under the drivers seat. The front and back panels on the seat near the floor, are removable by putting your fingers into the grill and pulling so it pops off.
    We have added another leisure battery, wired up in parallel, under the passengers seat but it involved removing the whole seat and then makeing a clamp to hold it in place as well as "adjusting" the foam on the floor to accept it.
    There are 2 waste tanks each with their own emptying system which is in effect just dumping it directly to the ground. One has a handle on the drivers side underneath near the habitation door and exhaust (when the water empties it drops on the exhaust and goes everytwhere!) and the other at the rear just inside the bumper bar. Both tanks have a twist cap on them to prefevt road dirt getting into the pipe, which needs removing first of course.
    I have another thread on the Mclouis forum about obtaining a flexible sanitation hose.
    We are out in our motorhome this weekend in the Hebden bridge area leaving around 5pm today so I will check on here before we go to see if this helps and if you would like any other information about your motorhome that i may be able to help with. When we return I will check again. If you want to PM me then please feel free to do so.
    Hope to meet you one day to compare notes.
    Roger & Marion
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    Hi and welcome, don't open the tap when your underneath!!:Rofl1::Rofl1::Rofl1:
    The pumps always are a biy noisy, shows they are working! or you can mount them on pieces of hose pipe to act as a cushion. pipe like this == with bolt going though hole in centre.
    Regards
