noisy inverter (1 Viewer)
Welsh girl
3,658
3,036
Globecar
Since 2004
We have just fitted a 300 watt inverter into our motorhome and I didn't realise they would be so noisy, are they all noisy or just the smaller wattage inverters?
It's a pure sine wave inverter from a local electrical dealer.
We are just running the tv and freesat box on it , but doesn't like anything else running from it.
Oct 14, 2007
3,989
6,247
Rochester
Auto-Trail Mohawk
16 fun filled years
Is it a noisy fan or is it squealing, mine does the latter if the connection to the battery is not good.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
When you say noisy, do you mean the fan is noisy. Some of them are, I had one that was so noisy I couldn't hear the TV. The one I have now is fitted in the garage and as far as I know the fan only comes on when needed. Have never heard it as its to far away.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
As others have said, you need to define 'noise'. If they suffer supply voltage drop from the battery to the inverter (usually caused by thin cable or poor connections) they will squeal. Otherwise, I don't know why a 300W PS inverter would make a noise. I have a 150W PS inverter from Stirling and it is silent in operation.
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
The fan runs noisily, it did beep when the battery went down.
We realised that running it through the 12 volt sockets run down the vehicle battery, not the leisure batteries which are fully charged through the solar panel.
luckily the sergent consumer box then charged the vehicle battery.
It's now connected to the 2 leisure batteries but the fan is still noisy.
43,326
49,441
having the fan run all the time the inverter is on is a cheap option.
good quality ones will have a thermostatically controlled fan...only running when needed.
a 300w inverter running a tv and digibox (probably no more than 60w) should rarely, if ever, need the fan.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
price doesnt always come in to it . some expensive ones have it running all the time .
i do know many disconect the fan and put a switch for it when using higher end of the scale items . they seem to last for years sometimes like it .
43,326
49,441
not always a question of price Alan......I said quality.
a few pennies for a thermistor and a bit more circuitry....even lower quality ones could do it.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yes sorry .i have a 24v 300amp in the cab came from radio spares . not cheap and you would think highish quality but fan stays on . luckily i only use it for walkie talkies or phone . and while driving cant here it . but it is a bit noisy if i switch off .
dont know what quality is these days . is there any goods made anywhere but china or africa .
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Mine's pretty noisy, but it is only used for short periods, such as for running the washing machine. Your TV and freesat box should be run off 12V, not via an inverter. It would be more efficient and much quieter. Most LCD TVs (at least the smaller ones) run off 12V with a external power brick, so you're just converting from 12V to 230V and back again.
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
The tv can be run off 12 volt but as we have a 240v freesat hd recorder and use it a lot for watching prerecorded tv shows and films to fast forward the ads, it would be more expensive to buy a new12v freesat hd recorder than buy an inverter so opted for the inverter to run them and other electrical items when not on hook up.
The inverter has saved us a lot in just the one week having to be on hook up just to run a few electric things, in the summer not needing heating.
