Noisy Fiat Ducato Door (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Love everything about our 2006 Autotrail Tracker EK except the wind noise that comes through the driver's door in certain conditions. Clearly the seal is not touching the door hard enough to stop the wind noise. I get no draught but a sudden scary whistling especially when being passed by large vehicles.
The door is held on by a pair of large hinges each mounted by three Allan bolts. Does anyone have any idea how I might eliminate the noise?
Many thanks
Jerry
Nov 6, 2013
3,201
229,212
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Cant help with your question Jerry but I have exactly the same problem on the same MoHo, same age.
In really windy conditions I can see the door move at the top :Eeek:
43,319
49,373
In really windy conditions i could see DAYLIGHT at the top.
Nothing you can do about it as the metalwork in the door is flimsy beyond belief.
if you got a hand trapped at the top it would take very little effort to bend the frame out...even shattering the glass.
I tried bending the window frame inwards (glass down) but didnt make any real difference.
Dec 12, 2010
5,408
21,551
Cumbria
since 2011
Be pleased if someone can come up with an answer, there's a slight gap on the hinge side of our door where the rubber seal just doesn't touch and there's no adjustment on the hinges :(
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Funny, I get that as well, but I just put it down to exceedingly randy female truck drivers looking down at my manly bulge as they overtook me. (y) I managed to put a stop to it by buying a turbo. :)
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
I saw a feature on "Wheeler Dealers" where Ed China the mechanic put a rubber tube inside the door seal rubber, ie cut it and then fed a piece of break pipe or something to bulk out the sealing rubber. I don't even know if mine is a tube though... He did it on a supercar.....
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
I moved the trap on the lock in as far as possible and it made no real difference. So I wound down the window and bent the top of the door in. It worked for me - perhaps you needed to use more elbow grease?
43,319
49,373
It worked for a while but knowing how flimsy the ducato doors are i would rather a bit of noise than a destroyed window frame.
I found the easy solution was that thing all ducatos come with....a radio volume knob.
Reactions: f6c
