Noisy fan.
Discussion in 'Tech/Mech General' started by Tom A, Mar 13, 2016.
  1. Tom A
    Tom A Funster
    Apr 26, 2014
    362
    343
    Thornton Cleveleys
    I've got a PSU2007 with a noisy fan.
    Can't decide whether to buy a replacement fan or send full unit off to Sargeant to have it fully checked while it's off.
    Any thoughts please ?
  2. f6c
    f6c Funster
    Nov 7, 2010
    3,248
    868
    gloucestershire
    Send it to Sargeant.
    • Like Like x 1
  3. Tom A
    Tom A Funster
    Apr 26, 2014
    362
    343
    Thornton Cleveleys
    Thanks for the quick reply.
    Not questioning the answer but what makes you say that ?
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,087
    2,927
    Kendal, Cumbria
    Change fan - buy correct size off eBay. Under £10 as opposed to ..................... ?
    • Like Like x 1
  5. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,916
    11,380
    E Yorks
    If the fan is accessible try vacuuming it in case it's just dust causing the problem.
    • Like Like x 1
  6. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,686
    St. Helens MERSEYSIDE
    Hi Tom I took my Sargeant unit off to strip down and clean as my fan was noisy it was full of fluff on the vanes, cleaned up nice put unit back together all plugged in fan still noisy but not as bad as before :rolleyes:
    • Like Like x 2
  7. Minxy Girl
    Aug 22, 2007
    9,916
    11,380
    E Yorks
    As an aside to this - it's a good policy to occasionally vacuum the fans on laptops, computers etc for the same reason!
    • Like Like x 1
  8. Tom A
    Tom A Funster
    Apr 26, 2014
    362
    343
    Thornton Cleveleys
    I've rang Sargeant and they want £85 to replace fan and check everything.
    I've cleaned the fan but still noisy.
    Just popping to local computer shop to see what they've got or I'll get one off internet.
    Thanks for replies.
  9. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,535
    1,421
    West Midlands
    Justin Beiber gets this trouble I believe! :LOL:
    Wyn
  10. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    262
    182
    Rushden, Northants, UK
    The most common noisy fans are sleeve bearing types.
    If you remove the maker's label from the centre of the body, you can often see the shaft and bearing underneath.
    A drop of engine oil in there will give you a couple of years of quiet running. Don't forget to put the label back.
    Peter
    • Like Like x 1
  11. Tom A
    Tom A Funster
    Apr 26, 2014
    362
    343
    Thornton Cleveleys
    Tried in vain to get a fan so I've lubed it up and re fitted.
    A bit quieter so will do for now.
    Thanks again for the replies.
  12. Motorhome Man
    Motorhome Man Funster
    Mar 2, 2016
    69
    159
    Upper Halling, Kent
    Hi all, i had the same problem with my unit, apparently on the very latest units the fan is thermostatically controlled and only comes on at 30 degrees. As you all know the fan only works to cool the in-built battery charger. You can of course turn off the battery charger at night if this is the inconvenience. I actually removed the fan completely as could not find the exact same on the internet. Obviously the outside temperature is low at the moment and inside is matched but since october and up till now have had no problem with high temperature in PCU, which I check regularly. What happens in the summer we will wait and see. Once again can always turn charger off. I have solar panel so for me is not a problem. Regards Luke
    • Like Like x 1
  13. Tom A
    Tom A Funster
    Apr 26, 2014
    362
    343
    Thornton Cleveleys
    Thanks Luke. I turn ours off at night. Always seems louder when it's dark.
