Noise when on hookup (1 Viewer)
MattR
4,104
38,863
Beds
Panel van
Years
When we plug into EHU, we get a humming noise from the leisure battery storage unit - I haven't been able to investigate exactly where from but the storage area has the 110 battery and something like an inverter. Any ideas what could be causing the noise - it is certainly loud enough to be heard when trying to sleep so we unplug at night.
MattR
MattR
4,104
38,863
Beds
Panel van
Years
Could be the charger but is it normal for them to make enough noise to be heard from several meters away?
And it if it the charger, can I turn the charger off at night but still retain 240v supply for the heater & fridge?
TheBig1
17,630
43,272
sounds very much like your charger's transformer is beginning to fail. switch it off at night by all means
Jul 1, 2012
714
1,817
Nr Whitby
van conversion
On & off since late70s
Our charger normally quiet but does have an internal fan that only comes on when the charger is working hard. Very low battery or too hot. Area blocked with coats, etc.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
When we plug into EHU, we get a humming noise from the leisure battery storage unit - I haven't been able to investigate exactly where from but the storage area has the 110 battery and [HI]something like an inverter[/HI]. Any ideas what could be causing the noise - it is certainly loud enough to be heard when trying to sleep so we unplug at night.
If indeed this is an inverter then they can make various noises depending on the loading being put on it. They usually have a cooling fan which may be noisy, particularly if badly worn and they sometimes squeel if over loaded.
As others have said it may also be a charger past it's use-by date which you should be able to switch off while still keeping your 240v supply.
bobandjanie
8,161
15,796
Javea, Spain
Pilote V600g
Or it could be a Sterling B2B....unless the batteries are fully charged when you hook up it can start charging and the fans will come on. Having said that it will not do that the whole time but it could be a few hours or so dependant on how much charge your batteries need. Jane
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Our charger makes a noise, I think it is the fan, especially when the batteries need to be charged after a spell of off grid parking.
As I understand it this is the type of charger that gives an initial boost to get the batteries up then it will go quiet and maintain the full charge. This is all quiet normal and has done it in our van since new (07).
As others have said it may be some form of inverter or transformer. We had an RV that had one fitted to change the voltage from 110 to 230 and that hummed, but not enough to keep us awake.
Maybe needs checking out by a qualified eleltrician.
Apr 10, 2012
32
14
Warks / Leics border
Low Profile Coachbuilt
Since 2012
With the EHU connected and on, just put your ear close to the leisure battery and double check that the noise is not coming from your battery. I had this problem last year and wondered where the noise was coming from. It was a knackered battery which was also giving off hydrogen and triggering the CO alarm. Checked the charger and that was OK. Changed the battery (both - although only one was was making the noise) and problem solved.
Oct 1, 2013
7,511
19,937
Lanzarote
Nil by mouth
Lots
Could it be your charger that's humming...?
You 'um it son and I'll play it :Smile:
MattR
MattR
4,104
38,863
Beds
Panel van
Years
Thanks for the replies. I'll experiment with turning off the charger etc. over the weekend. I'm hoping that I can isolate what every is making the noise so that we can keep the EHU on over night and then flick the switch to charge batteries etc. during the day when the noise is not so noticeable.
It looks like a new charger is cheaper than a new battery.
