No Spare Wheel
Discussion in 'Top Tips & Tricks' started by Antony bleasdale, Jul 12, 2015.
  1. Antony bleasdale
    Antony bleasdale Funster
    May 18, 2015
    68
    19
    Morecambe
    we have just taken delivery of our 1st motorhome and noticed there is no spare wheel, or any tools required to change a wheel if there was one. Instead there is a tek tyre repair kit which consists of a compressor and a canister with latex fluid in. Is this system reliable, is the canister for one repair only and if so where can replacement cartridges be purchased. I could buy a wheel, jack etc but it would be a pain to try and store
    • Like Like x 1
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,183
    14,954
    Leeds the one up North
    You will have a jack and tools somewhere! try under the passenger seat
  3. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,568
    14,113
    Scottish Borders
    It's a common issue. Do you have break-down cover? If so check the small print to find out if they will attend punctures. Mine does as long as you have a spare wheel unless the vehicle was supplied without a spare when they will attend regardless.
    The other question to ask is would you be able and willing to change a wheel on a 3.5 tonne vehicle on the side of a road / motorway? I wouldn't and I wouldn't let my hubby do it either - far safer to be recovered to a place where the wheel can be changed without danger.
    I now carry a spare tyre. If you alert the breakdown service to the fact you have a sparetyre to be fitted to the wheel but no spare wheel they can either send a truck with fittings that allow the tyre change or get you somewhere that can. It appeared to be the best compromise for us :)
    • Like Like x 4
  4. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,568
    14,113
    Scottish Borders
    Ours doesn't. The truck battery is under the passenger seat. The handbook says to call the recovery service!
    • Like Like x 1
  5. Techno
    Jul 28, 2010
    14,183
    14,954
    OP doesn't say what van it is.
    Some converter move the tools to the garage but X250 cabs at least are supplied initially under the seat.
    Could be under drivers seat but mine is left hand drive so on passenger side
    • Informative Informative x 1
  6. Techno
    Jul 28, 2010
    14,183
    14,954
    The reason for no spare is entirely a weight and cost saving exercise by the converter. If your van is sailing close to the wind on payload then forget it. If you have plenty of payload then there are options.
    Do not trust the converters figures they tell lies. Use a weighbridge!
    • Like Like x 4
  7. scotzsue
    scotzsue Funster
    Apr 11, 2015
    776
    715
    hull
    Our Fiat has a jack etc under the passenger seat according to handbook it should have a compressor and canister as no spare fitted.
  8. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,568
    14,113
    Scottish Borders
    This also begs another question. Would you trust your MH to be safe on a jack whilst you change a wheel on the side of a road? Changing a car wheel I always used to put blocks under it "just in case". These days I call the breakdown service :)
  9. Antony bleasdale
    May 18, 2015
    68
    19
    Morecambe
    There is definitely no provision to change a wheel, the van is an autotrail cheyanne, any ideas where spare canisters can be purchased, I will check my insurance, it's with comfort and does include roadside cover
  10. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,568
    14,113
    Scottish Borders
    Most car repair / motor factors carry it.
    Halfords do as do these people well as many others.
    http://www.eurocarparts.com/tyre-foam
    Do not treat it as a permanent fix just a way to get you to a tyre fitter. Many punctures can not be repaired by the squirty stuff anyway. And tyre fitters hate it.
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,357
    9,805
    once you have used the latex glue on a puncture, the tyre is ruined and cannot be repaired again according to my tyre supplier
    • Like Like x 3
  12. Antony bleasdale
    May 18, 2015
    68
    19
    Morecambe
    Has any one had the need to have a puncture fixed who have been insured by comfort, fully comprehensive horizon advantage, the small print is a bit misleading and I am not sure if puncture repairs are covered
  13. Techno
    Jul 28, 2010
    14,183
    14,954
    It's not idiot proof but I happily use mine
    • Like Like x 1
  14. TheBig1
    Nov 27, 2011
    7,357
    9,805
    to be honest with all my experience, it would be a desperate situation before i would consider risking using the supplied fiat jack. especially on the rear wheels. they were never designed to lift a 3.5tonne plus laden vehicle. one minor slip and it can be catastrophic or potentially fatal when the wheel is off
    • Like Like x 3
  15. Seajay
    Seajay Funster
    Nov 2, 2014
    78
    67
    Cornwall
    I had the complete valve blow out of a rear on my Transit based C I Meridien....It was on a Sunday and on a bit of dual carriage way somewhere up North near Sheffield , phoned Comfort and an RAC wagon came out in about 40 mins....The spare on those Transits is on a wire winch way under the rear, an absolute pig of a job to get at, but after much cussing Mr RAC did the job. I now have the spare mounted on my bull bar where I can get at it. The wire winch and jack will now go on Fleabay.
  16. Badknee
    Badknee Funster
    Aug 25, 2014
    3,709
    15,900
    notloB
    By the time you have come to a standstill from say 50mph on a flat tyre I would suggest that the spray foam in the canister won't do the job. Ring the recovery company with the tyre size and explain you need them to bring one with them or send a mobile tyre fitter out.
    • Like Like x 3
  17. Mack100
    Mack100 Funster
    Jul 27, 2013
    567
    732
    here
    The only thing I really dislike about our motorhome is the absence of a spare wheel. I've fitted a TyrePal system but I'm still constantly on edge when driving.
    I'm considering looking into the idea of carrying a spare tyre but the complete lack of available space means a custom built holder under the MH.
  18. Techno
    Jul 28, 2010
    14,183
    14,954
    That's what I did
    [​IMG]
    • Like Like x 1
  19. The Wino
    The Wino Funster
    Mar 23, 2012
    1,160
    2,074
    leicester
    No spare or jack on ours (Chausson ford base) no room for a spare
  20. Mack100
    Mack100 Funster
    Jul 27, 2013
    567
    732
    here
    @Techno100 That looks great but I could no more make that than fly to the moon:).
    I think there is a specialist somewhere north of London that could make a cradle.
