No Running Water !!! (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
I have a elddis sunstyle 140 MH
We was away last week with no problems at all.
I came to clean it today and found i have no running water ?
You can hear the pump running but there is no hot or cold water out of any taps,the pump light is light up and all relevant fuses are ok ??
As anybody had this problem before ??
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
Stupid question but are you sure you have water in the tank?
Less stupid point is that you may have an air lock - check each tap in turn trying to bleed any air out. I always start with the shower tap (just cold water) and then the other tap in turn. Once the cold is flowing I then go back to the shower tap and do the same for the hot.
6,872
7,991
Manchester
A class Hymer
Since the 80s
Is it a submersible pump or an in-line pump?
A submersible pump is inside the water tank and its lower end sucks in the water near the bottom of the tank.
An in-line pump is outside the tank, probably near the tank outlet.
TheBig1
17,630
43,252
This sounds silly but has got me out of trouble before. you need to try priming the pump. turn on cold tap, and put your mouth over spout and suck. doesnt work if the pump has failed but will generally clear an airlock or prime pump
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
It's i
It's a in line pump
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Yes loads of water in the tank !!!
You can hear pump clicking in but no water!!!
6,872
7,991
Manchester
A class Hymer
Since the 80s
So, when you turn on a tap, the pump clicks in. It's switched on by microswitches in the taps, I take it, not by a pressure switch that detects loss of pressure as the tap opens.
Can you get at the pump? Disconnect the hose from the pump outlet, and get someone to switch on a tap briefly. Does water come out of the pump?
No water? put finger over outlet and try again, to see if air pressure is built up.
If air pressure is built up, check for air leak/detached hose in the hose section back to tank.
If not, disconnect hose from pump inlet, then try the pressure test again. If no pressure, pump is faulty, probably split diaphragm or bit of dirt stopping a valve closing. Try flushing through with hose from house water supply. If there is pressure, pump is OK, there is blockage in hose from tank to pump. Possibly a failed one-way valve, possibly a kink in the hose (cold water hoses get more flexible in hot weather).
If water pumps out in the first test, there is a blockage after the pump.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
After having another look this morning,i decided to look at the water heater.
i noticed a clear pipe with a air bubble in it,so i dropped some water out the blow off valve,
I tried the tap and after a gush of air i now have water :)
But why would it do this ?? i could of understood if i had done a full drain down,but the tank was 3/4 full.
1,887
305,131
Wales
Adria Coral 660SP
25 years
Selfies mandatory?
