No power coming in 'help' (1 Viewer)
Smurfette93
5
Paignton
Bessecarr e560 2007
4 months
Good morning everyone.
Help! I emptied the toilet cassette yesterday and now it won't flush. What have I done wrong? Also when looking at the control panel it's saying that there is no power coming in. All help greatfully accepted. Thanks in advance.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Have you tripped the Incoming supply either outside where you hook up or the RCD/breaker inside the van in the consumer unit
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
is the cassette fully relocated? Check you have not disturbed any wiring in the locker. Do you have water, has it froze or maybe dumped it because the temp dropped too low. Have you tripped the power either in the house/ EHU post, or van. Is the power switched on at the control panel, is the zig unit actually charging
S
Smurfette93
5
Paignton
Bessecarr e560 2007
4 months
Ok. Thanks for replies. I've still got power in the van. The sink water tap doesn't seem to be flowing so fast now. There is half a tank of water so it's not that. Not frozen either. Power lights still on and nothing's tripped.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds like a low battery with insuffcient power to run the pump properly measure the battery voltage with a voltmeter directly across both terminals. how are you keeping your battery charged.
S
Smurfette93
5
Paignton
Bessecarr e560 2007
4 months
I'm on ehu. We couldn't get the heating working on electric either. Only worked on gas. If there is a problem with ehu then surely the sockets wouldn't work?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
if you are on EHU and the 240V sockets work then the 12v system is not being charged, either the charger is broken or it got switched off.
If you cannot find out how to switch it on then get a 4 stage battery charger and connect direct to the hab battery to tide you over for now. What make/model is your motorhome can you post a picture of the electrics panel so we can see the switches.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
How long have you had the van and have you ever had the heater on 240V. Do you know the difference between 12V sockets and 240V sockets?
If no one local can help and you can get ti Ilfracombe I'll gladly look at it for you free of course.
Scout
3,959
121,136
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
there is normally a switched spur to power the electric heater, somethimes its in the wardrobe, it may be switched off.
or possibly the trip in the consumer unit has triped,
this could allso be the cause of the battey charger not working ( if indeed it is not)
one stage at a time
HEATER
is the red light on the heater spur on/off switch on
is the control knob for the heater set correctly
is the thermostate turned full up
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
If this has happened since you emptied cassette toilet and was ok befor that point then something has been disturbed in cassette locker. (Is problem 12v system? Or just toilet flush?) inside locker is a pair of wires leading to flush switch and pump, there is an inline spade fuse there (on left of locker wall) check the wires and fuse. Also theres usually a pair of crimp joints, make sure both are intact, wire could have been pulled out of one. Also check fuse in fuse board power supply, if wires chaffed it could have popped fuse in board. (15 or 20amp spade fuse)
Also check that toilet cassette has been properly relocated and that the flush blade lver on cassette is not allowing cassette to fully insert.
Lance
Reactions: JJ
S
Smurfette93
5
Paignton
Bessecarr e560 2007
4 months
Sorted toilet! Waters fine. Yes we have had heating on before on ehu. We bought it about 6 months ago. It's a bessecarr e560 2007.
S
Smurfette93
5
Paignton
Bessecarr e560 2007
4 months
Can you see pics? One is showing the arrow as if electric is going out and the other is the electric box. All that concerns me is that it's draining the engine battery? image.jpgimage.jpg
13,079
101,442
Bolsover, Derbyshire
Hymer S800
not long enough
I cant solve your problem, but hopefully reassure you that you are not draining the cab battery, the display shows the habitation battery is fully charged, so that is OK and your charger must be working
It also shows that 0.0 Amps are being taken out, nothing at all is coming out of the battery
Scout
3,959
121,136
South Yorkshire
chic c line
what was the toilet problem?
the pics look like every thing is ok at the mains input,
so is there a in line switch to the heater (it will have a red light and just be on/off)
is it on?
when you turn on the heater at the controls, can you the heater relays clicking as you switch it between heat settings?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
the trip switch looks like it needs resetting, surely the switches should be down and showing green instead of red.
Flook
553
467
Chelveston, Northants
Elddis Autoquest 175
Since 4th January 2015, first registered in January
When the MCB/RCD has been activated it will be down, all these are in the correct position. Everything else looks good, like the others the loo box may not have been fitted properly. Make sure the loo blade is closed, remove the cartridge from the locker and refit, check inside to make sure you can open the blade and close it again, then try the flush.
Flook
