No Hot Water Flow (1 Viewer)
RS_rob
1,010
669
Turnford
over a Year Yay................
I have a full tank of water & the cold water runs fine but nothing coming out of the Hot taps.
I can hear the pump clicking something ive never heard before when the taps are off.
Open the cold taps & I hear the relay click & water flows
Open the Hot taps nothing
Ive opened what looks like a pressure relief valve outside & water flows until the pressure drops
Ive downloaded the instruction manual & its useless
Carver Cascade Rapide 2 with a pressure sensing pump
any ideas ?
water goes in one end & surely it should come out the other...........
I have a hammer...........................
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
most likely air locked, try opening all the hot taps with the pump off. then switch the pump on.
RS_rob
RS_rob
1,010
669
Turnford
Nope been doing that for 3 hours & no joy
RS_rob
RS_rob
1,010
669
Turnford
I suppose I could take my probe out & try to manually power the pump & see if that kicks any air out
RS_rob
RS_rob
1,010
669
Turnford
& that didnt work I can make the pump run but nothing comes out of the taps so im guessing a blockage somewhere or a valve i know of not
M
Madwife
Have your hot taps got a micro switch? If your cold water tap makes a clicking noise when turned on and none from the hot it may be a microswitch has gone.
Kath
RS_rob
RS_rob
1,010
669
Turnford
Some net reserch tells me there is a non return valve underneath & that it might be stuck hmm
RS_rob
RS_rob
1,010
669
Turnford
Kath
Nope............
RS_rob
RS_rob
1,010
669
Turnford
Ive had my hands up the back of the sink & no wires........
icantremember
8,332
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
With the pump turned off and one hot tap turned on (all other taps off) try sucking water through from the tap. Be very careful if the water is hot.
You could also blow down the tap which may dislodge any air lock.
