No horn
Discussion in 'UK Touring' started by widowtwanky, Apr 9, 2014.
  1. widowtwanky
    widowtwanky Read Only Funster
    Oct 19, 2013
    12
    3
    london
    Hi guys
    I have a swift sundance 590rs. In Feb had the horn replaced and now the new one has stopped blowing too. I have read on line that swift are notorious for this fault with the electric being a culprit.
    Should I get this one replaced or try to sort the fault within the electrics, if that is the problem.
    cheers
    wendy
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,454
    7,552
    Nr Watton in Norfolk
    I would be surprised if you have a second faulty horn, if even the first one was faulty.
    You can't really blame Swift as the horn is part of the base vehicle probably Fiat or Peugeot.
    The most likely cause is a wiring fault or horn button .... has the fuse been checked .... is everything else working as the fuse may cover various electrical items.
  3. JJ
    JJ Funster
    May 1, 2008
    15,014
    26,999
    You are a brave lady Widow Twanky...
    Starting a thread entitled "No Horn" on this site is likely to generate some sad and desperate but witty replies!!!
    Obviously you have checked the fuse for the horn... :thumb:
    JJ :Cool:
    • Like it Like it x 1
  4. hilldweller
    Dec 5, 2008
    27,739
    26,826
    Macclesfield
    You don't have much choice, it's a legal requirement.
    So easy if you have the skills, a voltmeter across the terminals and press.
    Trouble is the only way to get to the horn on our 03 FIAT is to take the nearside headlamp out. Quite easy actually. I then cured ours with a load of WD40 and wriggling the adjuster screw.
  5. Popeye
    Popeye Funster
    Sep 5, 2011
    7,985
    18,310
    New Forest
    No horn
    Sadly, I've reached that age where mine works intermittently..... :Blush:
  6. Yorick
    Yorick Funster
    Oct 1, 2013
    4,109
    6,033
    Lanzarote
    [​IMG]
  7. Mel
    Mel Funster
    Oct 6, 2012
    2,133
    2,155
    De Haan Belgium
    Yes i very nearly put I have the same problem.
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,915
    10,286
    i have been told viagra helps .... stops you rolling out of bed too:Rofl1:
    if a second horn has gone faulty consider changing it for a different type, like airhorns. first though you need to rule out a wiring fault or blown fuse
  9. widowtwanky
    Oct 19, 2013
    12
    3
    london
    There was no easy way to get all your attention, but to title it this way.
    Thanks for your replies, some were helpful. I will get someone to check my fuses and call the dealer to book 'him' in.
    wendy x
  10. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    That post must have brought back happy memories to some of horns being blown:Rofl1:
  11. shawn&emma
    shawn&emma Funster
    Nov 24, 2008
    270
    390
    Anywhere that takes our fancy
    I can honestly say that in the 4 years we'd have had our van the only time it gets used Is its mot. Is that a good thing, am I to calm a driver? How much does yours get used.
    Shawn
