no gas
Discussion in 'CI Motorhomes' started by the broons, Mar 23, 2008.
  1. the broons
    the broons Read Only Funster
    Feb 6, 2008
    3
    help put our swift suntor to bed last sunday.tried the gas appliances today only to discover we are not getting gas through.the motorhome is fitted with a truma gauge could this be the problem. ps plenty gas in the bottle.:helpsos:
  2. Gonewiththewind
    Gonewiththewind Read Only Funster
    Sep 13, 2007
    854
    35
    Lancashire
    Depends what gas you are using, should be propane. If you are running on Butane could have frozen?
    Don
  3. the broons
    Feb 6, 2008
    3
    Hi Don thanks for your reply but it is propane we are using.I seem to remember reading that there is a problem with the truma fixed gauges.
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,942
    Daft question (not being cheeky, used to work in IT support).
    You haven't inadvertently screwed the bottle top valve closed rather than open have you?
    Graham
  5. Gonewiththewind
    Sep 13, 2007
    854
    35
    Lancashire
    If Grahams sugestion doesnt work, Do you have or borrow a standard valve to try out.
    Don
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,741
    5,969
    Mansfield,Notts
    1.Turn off gas fully at bottle
    2,disconnect reg from bottle turn gas on --------no gas---replace empty gas bottle
    3.got gas---turn back off --re connect regulator and disconnect pipe into motor home from reg
    4.turn on gas ---no gas --replace regulator
    5. got gas--- re turn gas off---re fit pipes to motor home turn gas on
    6 inside motor home locate and check all supply taps are on (located in cupboard)
    7if all on you should have gas to all appliances if off--- turn on
    8. remove pipework from one side of tap check for gas
    All of the above is assuming you are competent to carry out the checks suggested and can carry out a gas soundness check after each joint is broken and re fitted
    A simple process of elimination
    Working with gas is dangerous
    Geo
  7. the broons
    Feb 6, 2008
    3
    Sorted
    Thanks all for your suggestions.We have now sorted the problem,after replacing the fixed gauge with an ordinary propane regulator we now have gas to our appliances.We have spoken to a local caravan fitter who confirmed that the Truma fixed gauge has a common fault with oiling up inside therefore requiring the gauge be replaced.TRUMA are aware of this fault but as yet have not solved the problem.Thanks again.:thumb:
  8. Geo
    Jul 29, 2007
    9,741
    5,969
    Mansfield,Notts
    The problem is a well known and documented fault
    The fix likewise
    Make sure the new reg is positioned higher than the gas outlet on the bottles.
    Geo
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,360
    5,378
    East Sussex 01-580-881288
    Just shows that FUN is the place to get the right info straight from the 'horses' mouth unlike some.
    Lindy and Geo are the stars. :thumb:
  10. GJH
    Aug 20, 2007
    27,349
    34,942
    Glad you got it sorted.
    Another thing you might consider is to replace the rubber hose which connects the bottle to the regulator with one of the stainless steel ones from Gaslow. From what I've read it is plasticisers from the hose which cause the problem; also they should be replaced every 5 years.
    Our van is 4 years old and we haven't had any bother but I decided to replace the hose anyway, just in case, when I saw a discount offer in Practical Motorhome.
    Another advantage is that the connection to the bottle on the Gaslow hose has a built in hand wheel so you don't have to use a spanner - which was very awkward in our gas locker. Previously I had to switch the bottles around when changing from one to the other but now I just need to unscrew from the empty and onto the full bottle - very useful in the rain at Newark last week :Smile:
    Graham
    Graham
  11. PatM
    PatM Deleted User
    Truma Gas regulator- B Holiday May 09
    Do you know, I must be the only thicko in the Motorcaravan community that didn’t know about this- but I do now! Arriving at Sheepcote at w/end and wife not being able to light oven to do pizza + bad news. Attempted to change cylinder (again) and v nice Warden warned me that the cyl wasn’t empty (which means the other probably wasn’t that I changed last month...) I phoned around Saturday morning , Peacehaven, Johns Cross, to no avail- its wonderful when everyone knows about the problem and what you need- but haven’t got any in stock. Calor were helpful (at Shoreham Depot) but were unaware of the issue. So- I disconnected the regulator to 'shake out' this oily liquid that everyone was advising me about- and not a sign of it- Connected it all back up and still no flame. Dismantled it, filled it with good old WD40 (which is know to dissolve oil) and hey-presto, after a thorough drying- all working again.
    I managed to source a regulator from Lee Davey - which has the 90 degree bend and will permit it to be mounted higher that the output of the propane- which meant some cutting of the bottle-box and careful manipulation of the 8mm copper feed to the 'van.
    So, I’ve sourced a 90 degree elbow for the old regulator- which I cleaned out again- this time using my workshop facilities, air compressor etc and I shall keep it as a spare-
    The point of all this- had I been (God forbid) 'abroad'- I would have been in deep doo doo. Why didn’t the manufacturers do a recall? It’s obvious after a few thousand failures that there was a design issue?
    One closing comment, to pick up on what another correspondent writes- working with Gas is dangerous- you are supposed to be Corgi registered. But having seen some of the Corgi installations. I rest my case- it’s an age thing...
  12. 45eEver
    45eEver Read Only Funster
    Apr 15, 2009
    267
    The regulations only require you to be competent to work on your own gas.
    There appears to be no definition of competent.
    They require the kit you worked on to for profit to be inspected by a Corgi registered engineer before they are commissioned.
    The stuff about only Corgi registered people can work on gas installations is a profitable myth.
    Your insurance company may want a current Corgi Certificate on your motorhome.
  13. SIFTA SAM
    SIFTA SAM Funster
    Jan 27, 2009
    480
    492
    Leyland Lancs
    I believe Truma have not done a recall on their regulators as they have put the problem down to 'dirty' LPG.
  14. Liz14
    Liz14 Read Only Funster
    Mar 6, 2008
    19
    Cornwall
    Hi,
    We have had same problem three times....have just bought gaslow s/s hose and regulator
    will let you know if this sol:thumb:ves the problem...Gaslow guarantees it will with a 5 year warrenty.
