No Gas possible faulty valve!
Discussion in 'Tech/Mech General' started by pogjones, Aug 22, 2009.
  1. pogjones
    pogjones Read Only Funster
    Aug 19, 2009
    18
    Been out in the motorhome for the second time only to find that we could get no gas even though the bottle was full and all taps were open. It now looks like the valve is the culprit as no gas is getting past it. I have been informed that there has been problems with oil leaking from seals and causing problems has anyone else come across this. The motorhome is only 13 months old so the valve will also be the same age. There is a black plastic cap on the side of the valve and what looks like a yellow button which appears to be solid so not sure what it is for. Any advice would be apreiciated.
  2. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    Yes had two regulators go in one year - known problem - regulator should be higher than bottles and it is said Stainless Steel tubing is better than rubber.
    Another thought - on some regulators you have to hold the button in for a while - have you done this?
    :Smile:
    Keith
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,335
    5,344
    East Sussex 01-580-881288
    Try a new regulator.
    Peter
  4. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,881
    Full timing in the van
    we had the same it turned out to be a faulty gas bottle we took it back and when we put new bottle on all was ok
  5. slickmouse
    slickmouse Read Only Funster
    Dec 30, 2007
    305
    Planet Mars next 2 Uranus
    Best thing is to use a match or lighter along the metal pipe to see if there's a leak dont use it near the rubber as you may melt it.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,922
    17,585
    YO11 2BD
    this is a wind-up isnt it? :Eeek:
  7. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
  8. slickmouse
    Dec 30, 2007
    305
    Of course its a wind up, I would always recommend a blowtorch but not everyone has them
  9. pogjones
    Aug 19, 2009
    18
    There is a small yellow buttun on the side of the valve, but it is solid so it will not press in at all.
  10. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    Regulator
    It sounds like the regulator, they are fairly easy to change but please check for leaks very carefully. I've changed one this week for exactly the same reasons.
  11. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    Whilst I and most others know this is a wind up such a post is just so irresponsible:Sad:, a newbie may not know any better:Doh:.
    So for anyone looking to test for gas leaks the way to do it is with soapy water
  12. slickmouse
    Dec 30, 2007
    305
    Pogjones! Hi
    Dont use the cruise control while you go into the back to make a cup of Tea.
    Dont stick your finger into the battery and taste it to see if there's acid in it.
    Dont put your hand on the gas flame to see what the tempature is.
    Dont stick your head out the window while appraoching a tunnel to see it the van will fit through.
    Dont call the customs officer an asshole in France and joke the coke is stashed in the inside "somewhere"
    Dont put a hose from the exhaust into the toilet while taking a dump to get rid of the smell.
    Put a big sticker on the dash with your credit card pin numbers and address.
    I reckon thats it although I'm sure the others in this forum will have their own health and safety tips
  13. Tiderus
    Tiderus Read Only Funster
    May 2, 2008
    232
    Tywyn, West Wales
    Nice one Slickmouse.
    Wish you had said earlier, as wife is still trying to find my testical on the roof? I Know I had two before.
    Rgds' G.
  14. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Easy test for the bottle, turn off the bottle, uncouple from the regulator a quick turn of the bottle knob will tell you if there is gas in bottle and working properly, I hope this helps. Pete
  15. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    glad i use the old fashioned regulators screwed on to top of bottles . struggle to remember if i ever had one go wrong. do remember the high pressure regs not good on 28mbr. buy them abroad except uk propane for next to nothing. this new bulkhead reg stuff is aload of junk i think.
