No 240 volt supply? (2 Viewers)
petrol tin glyn
123
95
Cardiff
autotrail cheiftain
since 2006
:xeek: i had the same checked everything all ok but no 240v any way started up the onboard genny run that every thing worked,shut it of all ok 240v back to normal strange or what ??:xThumb::xThumb:
petrol tin glyn
123
95
Cardiff
autotrail cheiftain
since 2006
"]Dirty relay contacts mains / genny changeover?[/QUOTE]
:xeek:thanks for the info was in spain when it happened panic stations but ended ok not happened since:xlaugh::xlaugh:
L
longdog
Banned
Apr 16, 2013
255
287
I spoke to a friend of mine today who used to have a a '58 reg Swift. He said exactly the same thing happened to him a few years ago. He spent a couple of hundred getting the fault sorted before some one asked if he had checked the battery in the control panel above the habitation door. He found it was corroded and starting to swell, he changed it and it worked!
I thought it was worth a try and took myself off to Maplins at 9:00am this morning. By 10:00am the battery was changed and my 240 volt was working in the van! Now that's what I call a result!
How can a £3.99 lithium battery cause the 240 volt supply to stop working?
Feb 27, 2011
14,731
75,861
UK
Self Build
I had a similar problem when I bought my very first motorhome.
It turned out to be the small adapter lead that converts the blue plug to the normal 3 pin plug. The cable inside the blue plug end of this had disconnected itself.
If you have a multimeter test the voltage on the output of the adapter.
Feb 27, 2011
14,731
75,861
UK
Self Build
Sorry I had opened this and not responded due to a distraction. Glad to hear you sorted it.
I am so glad I don't have a fancy motorhome whereby a cheap battery can stop 240V from working :xeek:
43,319
49,394
Completely over engineered for a motorhome.....just like the electrobloc control panel.
Yer car doesnt have this much complication.
L
longdog
Banned
Apr 16, 2013
255
287
Well I don't think I have a fancy MH, but it does seem ludicrous that a cheap battery can stop a 240 volt supply from working!
ambulancekidd
Sep 23, 2014
10,363
28,386
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
I'd be willing to bet that the fuse in your adapter has blown. There is a considerable load on the fuse when the MH is being checked over. I'm certain that the fault is not on your MH.
Robert.
ambulancekidd
Sep 23, 2014
10,363
28,386
Ayrshire Scotland
Swift Kon-Tiki 640
Yes, the fuse in the adapter should be a 13amp one but the MH can draw more than the fuse can handle.
Change the fuse in the adapter & all will be well again.
Robert.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The answer was posted above, did you click the link?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I find myself thinking "that should not happen" often when it comes to Sargent. We were wild camped next to an old couple on Skye and she said they had to leave because the heating had failed and her husband could not cope with cold, Sargent, unplug control to reset it, they have heat. She was so grateful she tried to give me £50.
Jaws is a great fan of theirs.
43,319
49,394
Robert.
Unfortunately the 3 pin plug on the adaptor lead will be rated at 13amps.......putting in a larger fuse (if you can find one that fits the plug) is foolhardy.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Not for a simple function like turning on a basic switch..
In this CANBUS world nowt is simple anymore.
I can see the attraction at design time, a shed load of thick 240 cables all over the place to bulky switches or a single telephone like CANBUS cable from a flashy control panel to a hidden relay box.
But 10 years on ( OK 1 year on with poor build quality ) and oh how things change.
Look at Jaw's pain for the incredibly simple function of extend/retract a step.
L
longdog
Banned
Apr 16, 2013
255
287
Well guess what? Went away for a few days and it happened again while connected to EHU on a campsite. At that point there was no load apart from the Truma water heater and we were not in the 'van at the time.
I went through everything again and couldn't get 240v working at all. Still, it didn't spoil our few days and I thought I'd look at it in more detail when I got back home. Did everything I had done before apart from changing the battery and it still didn't work. Had it connected to my household supply using a 2nd mains lead and nothing. Switched everything off and then switched it back on and it worked!
Plugged a vacuum cleaner in to give the van a quick clean and it stopped working again, since then, the only thing I haven't done is change the lithium battery in the control panel and it still refuses to work! The 'van is going in on Wednesday for it's annual habitation check, I think I'll ask them to check this out :(
