No 12v Help (1 Viewer)
Jul 8, 2008
1,137
1,467
Weymouth, Dorset, UK
c build
6 yr
need a bit of help please a friend on a site has no 12v elc
fuse in engine is ok
the van is a peu boxer 2.5 on a 56plate
TheBig1
17,630
43,252
flat leisure battery, fuse by control panel or other distribution fault
a few more details needed to give a better guess
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
there is no 12v when the engine is running (quite normal in a lot of vans), the fridge does not work on 12v UNLESS the engine is running, what exactly is the problem. Get it down here and I'll see if I can help.
TheBig1
17,630
43,252
does the van have a sargeant controller or similar? may of blown control pcu with the 240v surge
2bob
Jul 8, 2008
1,137
1,467
c build
6 yr
hi just got this from him
No got sola panel and running a cigarette connection of battery which is working fine and sola panel control telling me 13.7 volts
TheBig1
17,630
43,252
nothing to do with the solar panel, what make 12v controller is fitted? certain control boards are known to be weak and fail if theres a power surge on the 240v mains
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Does he have a switch in the footwell of the habitation entrance ?
That caught me out when I first got my van. It is for when you leave the van in the dark, it is a master switch for habitation 12v, and on return it is easier than charging about in the dark looking for a light switch.
