no 12v from generator
Discussion in 'Tech/Mech General' started by speed080, Jan 22, 2013.
  1. speed080
    speed080 Read Only Funster
    May 28, 2010
    43
    33
    hi i hope some of you wizzards can advise me
    my van has a onboard geny a wta traveller 2500 it suplies 240v ok but will not put charge into leisure batts but supplies garge to engine battery also the solar regulator(sunworks)showa fault on leisure battery side but not engine batt ,when van engine is running it charges all batterys.this has happend i think because i put van away at storage site and left on my 1000 wat inverter and the shower room lights thus flatening the leisure batts and trigerda alarm on inverter(low voltage).the van had been unattended for three weeks,all fuses and connections have been checked ,your comments will be most welcome i am in west yorks thanks in advance Dave
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    You have probably killed your leisure battery, get it tested
    Terry
  3. speed080
    May 28, 2010
    43
    33
    twin 110ah i hope not
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,031
    Liverpool.
    You can live in hope....but I tend to agree with Terry.
  5. speed080
    May 28, 2010
    43
    33
    thanks but when van engine running the leisure batt reciive charge,but not from solar or geny when van engine off
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Yes but are they holding the charge.? The engine will be sending the charge which I assume you are reading:Wink:
    Terry
  7. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    If you completely flatten them and leave them they are dead.
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,921
    10,296
    even a dead battery will show a charge when the alternator is running and will show a trasient float voltage for a minute or 2 after, but this does not mean the battery is holding a charge.
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    remove the hab batteries from the van and give then a full overnight charge individually then after an hour off charge take a voltage reading several hours later test the voltage again and see if it is holding.
    Though to be honest I think you have killed them. The inverter only ever need switching on when you need to use it, the rest of the time the quiescent current is wasting power.
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    Looks new batteries are in order.
    once a battery reachs around 10v and not immediatly charged it,s as good as dead.
    a wild guess but your solar and 12v genny outputs may need to see some battery voltage before charging can begin.
  11. speed080
    May 28, 2010
    43
    33
    thanks for info but why does the reading show no carge from genarator,the cotroll panel used to show how much charge it was recieving from geny but now shows nothing when geny is running.sorry but as youve probably realised ellecticity is not my fortey sorry last 2 posts explain im just slow at posting
  12. TheBig1
    Nov 27, 2011
    7,921
    10,296
    its because virtually no current is flowing
    think of electricity being like a liquid and the battery as a jar. when its charging, or in this case the jar is filling, you can measure this. if the battery/jar is damaged and wont take a charge, virtually no current can flow or the jar wont take any more liquid. this is obviously simplified, but the analogy of electric being a liquid does explain its operation.
    your solar panel will generate electricity given the correct light conditions, but is not going to charge a dead battery. if its wired with a battery to battery type relay or charger, it will continue to maintain the engine battery
  13. craig
    craig Read Only Funster
    Jul 26, 2014
    Hi all first time poster but wont be the last!
    I have recently purchased a motor-home with a traveler 2500h geny on board that was not working.
    When i removed the cover the whole air filter unit was missing, probably in someones workshop somewhere, anyway i have been in touch with dometic who are about as much use as T*Ts on a bull. i have also rang and been to see honda specialists who said the part is something that the manufacturer would have put on as it is not the standard part.
    i have been chasing my tail for 3 weeks now and im getting nowhere fast! can anybody help me please
    Thanks in advance
    Craig
  14. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,293
    3,094
    Kendal, Cumbria
    This might help:
    https://www.dometic.com/enie/International/Site/Customer-Center/Operation-Installation-Manuals/
