night heating (1 Viewer)
nahnotme
239
I just bought me a Winnibago Itasca sunrise...YIPPEEEEEE
and as I fulltimer cold winter nights can be a problem. When im on hook up I leave a fan heater on all night but what do folk do when wild camping ?
I dont fancy leaving the blown air heating on all night as I only need to warm the bedroom and I presume leaving a fan heater on will drain the leisure battery rather quickly ??
12-Bolt
36
South Wales UK
Not decided yet
Just researching at the moment
Two naked bodies. :Eeek:
Jul 29, 2007
6,526
39,278
Ipswich
RV and PVC
30 years
Hi winnie heating an RV with electric is only practical on EHU, even a small 400watt panel heater running from an inverter, is going to kill anything but a massive battery pack overnight.
Even your gas blown air heater is problematic without a decent set of batteries, as the fan draws around 10amps, and left on all night in cold weather will probably flatten or seriously deplete a couple of batteries.
I would say your choices are extra blankets, extra batteries or extra bodies. ::bigsmile:
Olley
scotjimland
2,076
8,975
Suffolk Coastal District, UK
Timberland
As a full timer myself I would say an EHU is a must for winter.. except a one night stop over..
If you want to wild camp then you will need a big battery bank, run the a genny daily to charge the batteries and have a decent multi-stage charger fitted, the bog standard power supply unit fitted to most RVs is pretty useless at charging properly.. or...
Alternatively you could fit either a catalytic heater which uses no leccy or a wood burning stove ..:winky:
Jim
