niesmann and bischoff split charge relay/fuse (1 Viewer)
Nov 14, 2009
425
252
normandy
c class
16 years
hi all , just asking a question for a friend . he has a year 2000 niesmann and biscoff flair and the fridge and battery charging is not working while the engine is running? i had a brief look around but cant see the split charge relay or find the appropriate fuse? thanks for any help , happy xmas sean
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hi,Seanoo on my van the split charge relay is next to the engine battery 2.8 jtd I think it may help if you say what engine your friends van has :xThumb:
scotjimland
2,086
9,024
Suffolk Coastal District, UK
Timberland
as said.. ^^^ relay under the bonnet..
the fuse is the most likely culprit.. look for an in-line fuse on the feed to the relay
Lenny HB
52,698
147,629
On the coast in West Sussex
Hymer B678 DL
If his van has an Elecktroblock or CBE charger & control panel it will be incorporated in the charger unit.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
For year 2000 it should be on Fiat 2.8 and should be CBE, has your friend got the original manual as it is very good at giving position of all fuses and relays basically anything added by the factory is itemised. I could look in our manual if he is stuck but we are 2005 build date IVECO but the manual does cover the tag axle FWD as well.
Martin
