Newbie
Discussion in 'Motorhome Chat' started by John Hinch, Oct 17, 2013.
  1. John Hinch
    John Hinch Funster
    Sep 3, 2013
    8
    Donington, Spalding
    Without trying to sound like a bit of a plank can someone clear up a quandry of ours regarding mains connection. If we hook-up to 240 volts, is this just to keep the battery charged up or can we use conventional 240 volt items in the three point sockets. Is it necessary for us to buy a 12 volt toaster or TV for example or can we use normal mains electrical items if we are hooked-up to the mains on a site?
    Thanks for any non-insullent replies
    Regards-" Plank of the day"
  2. stevensson10
    stevensson10
    Jul 9, 2012
    648
    253
    normanton
    hook up
    of course you can that's the whole point of hooking up although when you hook up it keeps your battery on charge as well. but always ask on site what electrical devices to use at one time.for instance can you use the kettle microwave hair dryer all at once.some sites differ as to power strength steve:thumb:
  3. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    the ehu provides both ,mains power thru the sockets and 12v battery charging as well . one thing to bear in mind though is that different sites {esp abroad} supply the mains power at different amps so you need to check first before you go pluging in fires ,hair dryers etc !! regards garry
  4. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    There is a formula :BigGrin: volts x amps = watts.
    Put simply if site has a 10Amp supply,then 240v x 10A = 2,400 Watts.
    All your appliances should have wattage marked on them.Exceed that and you will trip ,certainly,your EHU post and maybe that of others.
    It can be fun,as we found in Portugal with only a 4Amp supply once :BigGrin:
    Mike
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Hi and welcome to the site. most points covered however, you never ever should use 12V for heating appliences such as toaster, kettle, hairdryer. You will flatten the battery in no time and possibly kill it. Toast and kettle use gas for hair dryer stick head out of the window.:thumb:
  6. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    Hi and welcome to motorhome fun.
    Although we banter amongst ourselves at times we never mean to be deliberately insulting.
    You are not by any means "a plank" all of us knew absolutely nothing about motorhoming once, so just ask away I am sure there will be more questions as time goes on and I will guarantee that a funster somewhere will give you good advice and help. Dont forget to use the search facility and there is loads of advice and tips on here
    Happy Motorhoming xxxxx why not join funsters at a meet/rally dont forget to check the calendar
    • Like Like x 1
  7. grasscutter
    grasscutter Funster Life Member
    Oct 11, 2009
    1,361
    2,261
    East Wittering. West Sussex.
    Not a silly question at all. If you don't know something much better to ask. A sense of humour helps which you seem to have.
    If you are buying a tv for your motorhome its better to get a dual voltage 12/240v model then you can use it if you are not on hook up.
    Any more questions ask away.:thumb:
