newbie with Hymer Exsis 562 Question
Discussion in 'Introduce Yourself' started by D.ten, Feb 15, 2016.
  1. D.ten
    D.ten Funster
    Feb 15, 2016
    88
    28
    inverness, highland
    Hi All,
    i thought it was time to join a proper motorhome site now that im about to pull the trigger on a hymer after years of other vans.
    im looking at heading out to Germany to pick up a 2014 (2013 production year) Hymer Exsis 562. ive done all the research, spent hours on google finding out about all the good and bad bits (headlamps!) but we now know that this is the van for our needs.
    my question is, ive heard that you can change the direction of the headlamps fairly easily on some Hymers (L and R 'switch' behind the lamp?), does anyone know if this is the case with the exsis 562. ther eis no way i can get a UK spec set fitted at 900 euros each!.
    cheers for now
  2. Neckender
    Neckender Funster
    Oct 15, 2007
    1,369
    1,680
    Neckend or Benidorm
    Welcome to the forum D.ten.
    John.
  3. f6c
    f6c Funster
    Nov 7, 2010
    3,436
    906
    gloucestershire
    Welcome aboard;)
  4. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,910
    6,818
    West Sussex
    Behind the Almond Eyes they are just standard Hella Projector lamps. A lever on the back adjusts them to flat dipping which is acceptable to the VCA.
    • Like it Like it x 3
  5. Xabia
    Xabia Funster
    Jan 20, 2011
    794
    523
    Rural Nottinghamshire and Spain
    The only problem is that you need to be a contortionist to get to the levers! On my B544SL I have found that the easiest way to do the adjustment is to remove the headlight assembly, very simple when you know how.
    This is the procedure on my van, imagine yours will be very similar
    Hymer headlight adjustment.
    I watched a HYMER mechanic replace our n/s headlamp a year or so ago.
    He removed the grey mesh grill above the light via three screws. The top two are hidden in the grill. (above).
    He then extracted the three bolts allowing the headlamp unit to pull forward from the bottom. (above)
    Looking at the rear..... when you remove the large rubber cap you can see the metal lever Hymie mentions. In fact, there are two (both do the same job) opposite each other.
    You can make out one of the levers (left) here. It is thin, and doesn't feel substantial, but will slide about 1.5" (from memory).
    So.... without removing the headlight.......If you take a good look at this last picture, remove the large rubber cap, and feel inside. The recess is quite deep, but if you keep your fingers to the edge you should be able to feel one of the levers. In fact, each one is between two cross head screws.
    I can see the alignment move as I switch from one position to the other.
    Re-fitting the rubber cap is straight forward.
    Hope this helps.
    Mike
  6. Speve
    Speve Funster
    Jul 29, 2013
    2,227
    1,916
    Salisbury
    If you are importing it you should get the dealer to sort that out for you as it will need to be done prior to registering in UK as will speedo dial.
    We imported our 2014 Exsis 698 last year through Bundesvan they did all the necessary including delivering it to our home saved a lot of hassle,of course you can do it all yourself good luck with it they are a great van.
  7. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    Buy a speedo from Lockwoods and send direct to dealer to change as well. You will need dealer to take photo with ignition on and send this to Lockwoods to get the correct model....have fun and good choice!:)
    Edit...unless on Ford chassis...fiat much better!
  8. 504329lt
    504329lt Funster
    Nov 19, 2013
    102
    60
    york
    I imported a Hymer Exsis I 562 from Germany last February. Our mechanic changed light bulb settings fairly easily. He wouldn't touch the speedo though for fear of breaking it so we had to get someone else to fit inlay (from Lockwoods).
    Mine has Ford chassis; all seems OK to me.
  9. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,333
    3,651
    Rural South West Wales.
    Welcome :)
  10. StitchesnFluff
    StitchesnFluff Funster
    Oct 18, 2014
    1,245
    532
    Salisbury
    Welcome & enjoy your travels
