Newbie requires info on Ultrastore pub connector. (1 Viewer)
Deeps
11
Plymouth
Fiat Ducato Conversion
Since 2014
Hi, I've just joined the forum but I have been viewing info on interesting topics in the past and everybody seems to be very helpful.
My problem at the moment is I had a leak from my Ultrastore Water Heater (10ltr) and having panicked with the amount of water mixing with electrics disconnected the pcb and removed it.
I found the water leak is the seal on the element so disconnected the cold water input and put a 12mm stop in line so we could at least have toilet flush and cold taps.
Having now relaxed a bit I noticed the remote connector on the cable has 5 connections on it however the connector on the pcb has 6. Now I can connect it using the 5 pins nearest to the pcb edge or furthest, which is it to be? I can take photos if required tomorrow.
Thanks in advance, Ray.
Deeps
Deeps
11
Plymouth
Since 2014
Thanks David, just noticed good old auto has put pub in title instead of pcb, is there a way of editing?
TheBig1
17,509
42,755
connecting to a pub is often more fun though
Apr 10, 2010
548
538
Bedfordshire
Carthago
Since Sept 2003
Is that a Truma? If so, I've always found Truma technical support by phone very helpful. Some time ago they talked me through a series of tests to diagnose a fault. (Turned out to be the meter I was using :mad:)
Anyway, give them a call and good luck.
