Newbie question (1 Viewer)
crimbo
25
8
Hampshire
"I`m a newbie"
Hello peeps,
Am I right in assuming that the leisure battery is charging when the motor engine is running or the 230v mains is connected :Smile:
43,323
49,433
yes and yes.
though the split charge from the engine isnt very efficient.
once the engine battery is fully charged, which doesnt take long, the alternators output is reduced to simply maintain the battery, so the leisure battery charge is also reduced.
hookup, of course, charges via the onboard charger.
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
yes and yes.
can you explain how the alternator knows which battery is full as when the split charger is operated the alternator surely sees them as one battery bank
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
In a basic system both batteries are charged whilst the vehicle engine is running. The relay disconnects the vehicle battery to avoid discharge by leisure circuits when it's not. The relay's coil is commonly supplied from an ignition circuit, like the alternator warning light. After that you can have voltage sensing, to direct charge or solid state devices to do the lot and connect things like a fridge to the relay to operate it whilst on the move.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Typically, the manufacturer uses thin, high resistance cable between the two, with a cheap high resistance split charge relay, that results in the engine battery charging much more quickly and the alternator sensing that battery's state. Occasionally, the batteries are adjacent and have decent cable and relay, but you'll have probably fitted that yourself.
Another alternative is to fit a proper dc to dc battery charger, which will charge the leisure battery properly.
43,323
49,433
thanks, you put that much better than i could.
i started to reply a while ago but couldnt find the words to explain what i meant.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
And if you have fitted the relay yourself, with decent sized cables, you'll probably boil your leisure battery. The circuit needs some resistance to avoid 'high' voltages across the leisure battery. 14.4V on a deeply discharged leisure battery won't do it any good but it shouldn't harm a lightly discharged vehicle battery.
I agree, B2B charging is the better option and, of course, can be added to a 'van with an existing split charge installation.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Hi and welcome to the forum. The answer to your question is not very well and quite possibly.
The split charge arrangement will never fully charge the leisure battery unless you have a battery master fitted for reasons given below.
When on mains hookup the leisure battery will charge properly provided the onboard charger is
a) working,
b) switched on and
c) switched to the hab battery.
solar is so much simpler for most of the year.:thumb:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Yes, best to stick clear of a split charge relay if you are using a sealed battery that can't take a decent charge rate. A B2B charger will have proper microelectronics to moderate it to a suitable value.
