Newbie Needs Help Please - Control Panel (1 Viewer)
treasuredgiftsuk
89
18
Portugal
I'm a newbie
Hi, we bought a 1995 Fiat Ducato Wineberg Toskana motorhome yesterday. It is the first one we have ever owned and we do not have a clue.
Unfortunately the owners handbook is in German and despite trawling the net have been unable to find any help regarding an English edition.
What I am totally baffled by is the control panel and what the different switches are for. Does anyone have one of these or something similar that could help me out with this problem.
If posting an image of the panel would help I could take a photo tomorrow.
Thanks in advance.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
lots of German speakers on here so a decent legible photo would really help, failing that a list of words needing translating.
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
Control Panel Help
Hi all, will really appreciate any help on the following. I have manage to work some of it out but not all.
My questions are as follows:
When I am parked up outside my house and not plugged into the mains should the large switch bottom right, with the 12v battery symbol be on or off?
What should it be set to if I hook up?
The light above this switch is lit green, what does that mean and is this an indicator for the leisure battery or the vehicle battery?
What is the on off switch next to this indicator for?
The rocker switch with the 3 symbols above it: If I switch it to II the 12V light is red, does this mean my vehicle battery is getting flat or is it for the leisure battery and what does the I and II signify.
What exactly do the red buttons for the various fuses do.
Sorry to be such a pain but I am totally clueless and the hand book is no help at all as it is for a Fiat Ducato van.
Image below:
Broken Link Removed
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi Lesley,from what I think I can tell
top left switch to turn water pump on
second left looks like switch for waste level and state of battery level (lights above)
third switch poss to turn heater on
forth is light to say battery charging?
straight below forth -looks like it could be switch to turn heating or boiler on or poss turn on/off all 12v power
bottom row are fuses Take out one at a time and see what works/does not work
terry
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
terry
Hi Terry, many thanks just to clarify:
second left looks like switch for waste level and state of battery level (lights above) I am sure you mean leisure battery but just to make sure is it?
forth is light to say battery charging? No can't be that as it is lit green and not on charge. It can be pressed and just pops out again doing nothing.
straight below forth -looks like it could be switch to turn heating or boiler on or poss turn on/off all 12v power. If it was the latter does that mean I only have this switched to on when hooked up?
I also asked in another feed the following: As the sate of battery light is red when I press this switch it means the leisure battery is low, would hooking up to mains also charge the leisure battery and would this be automatic.
Thanks, sorry to be a pain.
43,329
49,441
left rocker switch = water pump with 'on' indicator light above
centre rocker = fresh/waste water level and battery state. press lelt hand for fresh and waste....green light ok....red light = fresh low/waste nearly full. press right hand side for battery state...green ok/ red low volts
right rocker = heater on/off
green indicator....could be panel on/off indicator
lower buttons may be mini brreakers, not wired fuses.
left (1)= fridge
next right (2) = heater control/ignition and lights
next three (3/4/5) = ? (could be 12v sockets, aerial booster, cooker ignition etc)
large rocker turns off breakers 3/4/5
truma vent rotary knob = fan speed...red slide switch position = up for manual fan speed control, centre = fan off, lower = auto fan speed control
truma boiler rotary knob = temperature selecter.....red light = flame out/failure, green light = boiler lit
dont rely on the water/waste indicators being anywhere near accurate, they very rarely are.
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
left (1)= fridge
Pappajohn thanks a million, all sounds good to me.:thanks2:
Steveutwg
41
26
Rushenden, Kent
Bessacarr 560
25 years
Hi Guys
I have seen one of these before, all be it some time ago, connect up to the Mains, put a voltmeter across the leisure battery, take a reading, if the battery has power in it, you should get a reading of around 12 volts, or less depending on it's state of charge.
Now switch on the large switch bottom right, this should turn on the leisure battery charger, take another reading the voltage should go up, if the charger is working ok, your control pannel is the fully electronic type with leisure battery control, so you should be ok, for a bit, but it would be worthwhile having the system tested.
If you dont have a meter, put on some of the internal lights, then turn on the large charge switch on the pannel you should see the lights go brighter as the charging system kicks in.
Good Luck
Steveutwg:Cool:
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
Hi Guys
Good Luck
Steveutwg:Cool:
Hi Steve, thanks for the reply. I have got a bit further since you wrote this and discovered that the large black rocker switch turns off all internal power ie lights to the van. It is an old girl so old type of panel 1995.
I hooked up for a few hours with the transformer in the wardrobe on and all the lights on the panel are now green so think that has done the trick for now.
Will have to buy a voltmeter to get a better reading. Cheers.:thumb:
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
The little green light that pushes in: on ours it lights up when pressed in when on ehu. :thumb:
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
Our little green light with the battery symbol below is on all the time whether we push the button in or not er what is ehu, :Blush:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Electric hook up = ehu -when plugged into electric :winky:You should have a electric distribution box with trip switches -either where you plug in the side of van (inside) or very close to it.From there it go to your Control panel which goes to various bits around the van IE charging unit, lights, heater, boiler etc
terry
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
terry
:Doh::Blush: Sorr Newbie here not thick honest.
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
No probs ::bigsmile: you will soon know all about your vans leccy bits :winky: A good idea to write down what does(fuses etc) what and keep it in the van.
terry
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
terry
Good advice Terry ..... where's the writing smilie? :thumb:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
:Doh::Blush: Sorr Newbie here [HI]not thick honest[/HI].
I've already told em, will they 'ave it? No, I keep tellin' em, but No they won't Bloody 'ave it!
Listen, it's guys like you who ask, what you call silly questions, that educates is silly beggars who haven't got the gumption to ask in the first place so you KEEP ASKIN'.
I'm learning loads, often from papajohn. . . . . .Griff .
:thumb:
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
:thumb:
:ROFLMAO::ROFLMAO: Hi Griff, will do at the risk of seeming clueless. But as the saying goes if you don't ask you don't get!
:thumb:Yeah papjohn is a mind of info.
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
Huston We Have A Problem
Today I decided to try the sockets in the m/h and guess what, they don't bloody work.
First off, the lights work and the water pump works so I am assuming that the Calira EVS12/07A does not have a problem.
If you look at the start of this thread you will see an image of the Calira Bord Control 836 and I was told in an earlier post that 3, 4 and 5 with the red buttons at the bottom of the board were for the sockets. Ok here are my questions.
Could it be a blown fuse and if so are these behind the control bord which is located in the ski-locker and when casing is removed looks like spagetti junction.
What are the red buttons on the control bord supposed to do. When I push them in they just spring straight back out again?
Please don't think I am just being lazy I really have tried to research this problem but all I can find is a wiring diagram in German and I can't make head nor tale of it.
Any help would be appreciated. This is driving me nuts.:cry:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Are you talking 240V mains sockets ?
These are nothing to do with the 12V Calira panel.
Those resettable breakers with the red buttons will pop out if they get an over current on 12V.
Any 240 sockets must have something like you are used to in your home for protection, probably not far from when the hook up cable plugs in.
treasuredgiftsuk
treasuredgiftsuk
89
18
Portugal
I'm a newbie
scroll down for a wiring diagram
http://www.calira.de/de/dt/download/anschlussplaene.php
http://www.calira.de/de/tools/anschlussplaene/46.pdf
somebody may be able yo translate from there
Do the red lights twist and pull to reveal fuses ?
terry
Do they have auto electricians nearby-it could be worth spending a few quid and let them see what does what-but remember to write down the findings
Hi Terry, they do not appear to be lights but red buttons that you can push in a spring straight back out again.
We are in Portugal so taking it to a specialist would be a bit of a problem with the language barrier so will maybe have to wait till we get back to the UK
