Newbie - help with fridge issue (1 Viewer)
weehee
Ayrshire
Low Line
Newbie!
Hi all, I am the proud owner of my first ever motorhome, Bessacar E645. The night before we set off, I plug the van in to top up the batteries but I have noticed when I switch the fridge on it still runs on gas. The fridge chooses whether to run from gas or electricity but I was told when its hooked up it will always choose electricity. Can anyone advise if this is normal? Thanks.:thumb:
dennismartin
135
19
hull
c class
im a newbie
i would check the fuses first make sure its plugged in
W
weehee
Ayrshire
Low Line
Newbie!
Thanks for the advice, The fridge doesnt have a way to change the power source manually so I will check the fuses. Thanks again!
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi weehee and welcome :thumb:Turn off the gas to your fridge there by forcing the fridge to select leccy ::bigsmile:
terry
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
My fridge has an electrical switch in the wardrobe. A 240v master switch I suspect. If its not on, your autoselect would have no option but to choose gas.
Just a thought.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Which model fridge do you have?
My Dometic Fridge freezer has an auto change over, it sas "AUTO" on the display along with a symbol for either a mains plug, a gas flame or a battery, to indicate which is in use. On auto it will choose mains if it is available.
However it is possible to change it to manual selection by pushing a small button next to the LCD display. The AUTO goes off on the display and by pushing the button you choose, mains, gas, battery or back to AUTO.
If yours is similar check that AUTO is selected, perhaps it had been left on manual by someone pressing the button inadvertently....
It will only run on battery when the van engine is running.....
