Newbie Engine Trouble
Discussion in 'Bessacarr' started by idbrown, Nov 9, 2011.
  1. idbrown
    idbrown Read Only Funster
    Nov 9, 2011
    Cheshire
    Hi Guys,
    I'm new to the forum and but have been the proud owner of the Bessecarr E410 Ducato with the M-jet 2.0 deisel engine since 2008.
    It has 11500 miles on it and since our last trip we noticed a knocking sound from the engine.The guys at ouir dealership have already checked the injectors and are now suggesting it could be a "dropped piston" and could cost upto £2000 to repair :cry:
    Has anyone else had any issues similar to this ??
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,315
    8,026
    West Norfolk
    Dropped piston?!!!!!!
    If a piston detached from a con-rod, I'm surprised it runs at all!:Eeek:
    You'd have much worse than just a knock!
    Has this diagnosis actually been confirmed with a compression test?
    If your motor is indeed kaput, I would suggest it might be best to find a breaker who can supply a whole engine. It should be a lot more economical than repair of your present lump.
    Make sure you change the V5 engine number details if you go down this route though.
  3. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,143
    13,795
    Ramsey, Isle of Man.
    What's a dropped piston?
    Craig
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
    Drropped piston, what is that?
    I would suggest you take the van to a Fiat Commercial dealer or a specialist diesel engine company.
    Peter
    • Like it Like it x 1
  5. idbrown
    Nov 9, 2011
    Cheshire
    Thanks guys,
    Just reviewed the message from the dealer and I mis quoted him.....
    He said after speaking to many diesel specialists it sounds like the engine has "picked up a piston and the engine will need to be removed"
    Still none the wiser to what this means and as it's been with them for three weeks, I'm not convinced that they know either.
    any ideas ??
  6. RKE
    RKE Read Only Funster
    Sep 21, 2011
    94
    82
    Somerset
    Sorry, but I'm none the wiser either!
    I've heard of 'piston slop' 'big end' and 'little end' wear,.... but not your 'diagnosed' problem.
    Maybe someone on here will be able to offer an explanation soon......
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    never heard of picking up a piston, picking up a liner maybe, sounds like a bit of kidology to me take it to a main dealer. Or just get a secondhand lump to put in.
  8. laneside
    laneside Funster
    Aug 14, 2009
    3,588
    5,625
    Oradour sur Vayres
    Are you sure of what they said because I think they said----------------------------------------------------------------- ''they were extracting the pi$$''
  9. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    What I think they mean is "A piston has picked up" meaning a temporary seizure and scoring of the bore. If this being the case it should be burning a drop of oil. Is it smoking ???. It shouldn't be knocking if this is the case unless the piston rings on that cylinder have broken up.
  10. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,143
    13,795
    I never did hear of a dropped piston, and i sure did never hear of a piston being picked up either.
    Craig
  11. Snowbird
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    A piston picked up is terminology sometimes used by older mechanics to describe a partial seizure. It normally happens after a rebuild if the clearances are not enough, but in this case the vehicle has only done 11500 miles so that's unlikely. The other cause of partial seizure can be overheating or oil contamination.
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    just out of interest...how did they check the injectors ?
    a poor spray pattern caused by worn/damaged injectors will cause diesel knock and the only way to check that is removal and proper bench testing to look at the spray pattern.
    contaminated diesel can cause premature injector nozzle wear.
    a partial piston seizure shouldn't cause a knock but may result in oil smoke from the exhaust
  13. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,143
    13,795
    Not only do they look at the spray pattern, they also check the pressure needed to cause the spray and it has to fall within tolerances.
    Craig
  14. maxsdad
    maxsdad Funster
    Oct 5, 2009
    302
    239
    anglesey
    usually if anything drops its a valve
    this will damage the piston crown and will make a hell of a noise
    you do not say if you have any other symptons which would suggest a timing problem the timing belt may be slack or jumped a tooth or the injector timing which is electronically controlled by the onboard computer may need adjusting the vehicle needs pluging in to a diagnostic machine to check this usually at a main dealer
  15. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    true, but low/high pressure should also affect the spray pattern to an extent but neither of which can be checked with injectors in situ
  16. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    PICKED UP A PISTON ?? IS IT TRYING TO BECOME A V8 CHEVY AS MY CHEVY RUNNS GREAT :Blush:
