Newbie , draining main tank ducato mobilvitta 61
Discussion in 'The Beginner' started by Tracey, Dec 16, 2014.
  1. Tracey
    Tracey Read Only Funster
    Dec 14, 2014
    4
    Cambridge
    Hi all picked up my first motorhome today , yahoo , moilvetta 61 2000 plate . Still learning all the bits but need some help
    How do I drain the main water tank that is situated under seat ? I've looked underneath but can't find any taps
    There are two black handles at rear and when I pull these lots of water comes out I am presuming waste ? But water tank remains full ?
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    not sure of your model spec but some tanks have an access lid that you remove then the drain is inside... mine is such.
    if you have 2 handles underneath one will be waste whats the other? it could be the main water tank.
    ohh.. and welcome to Fun:xThumb:
  3. Tracey
    Dec 14, 2014
    4
    Cambridge
    Enjoying it already, I've pulled both black levers but these don't drain main tank, under the sat here is a big white tank with a fill up hole on the outside wall for fresh water , I've opened every hatch , it's driving me mad , want to drain down as don't know how long waters been in there
    It's a fiat ducato mobilvetta 61
  4. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,088
    9,706
    Lorca,Murcia,Spain
    If like mine where the water tank is inside the MH under one of the seats that form part of bed, then there probably is no drain. Mine does not have one as everything is run inside the vehicle , I assume for winter use, & the only exception is the grey waste tank which is outside right at the back.
    Hope this helps & welcome to Fun ! :xThumb::welc:
  5. sleep e carr
    sleep e carr
    Nov 30, 2008
    109
    31
    Whitby North Yorkshire
    Hi I have the same thing with my Talbot express grey waste tap outside for sink and one for basin/shower but nothing for water tank under bed unlike my last van, so when I come back from Christmas holiday I will 1/4 fill water tank with water put some Milton sterilizer in leave it a couple of days then turn cold on, and waste tap on and let it drain down, sounds like a waste of water but you will clean fresh tank for new season. hope this helps don't forget to drain down hot water, it's the big white plastic screw below vent on the outside.
  6. Tracey
    Dec 14, 2014
    4
    Cambridge
    Thanks everyone for advice , looks like I'm going to have to turn taps on and open waste to drain , got lots of little jobs to do but it's all new and exciting
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    If your tank has a large (7"or 8") screwed cap on top, maybe red or black, then take off/unscrew the cap and have a feel inside on the tank bottom.
    There may be a removable bung.....remove it and water should flow out of a drain in the van floor.
  8. chopper602
    chopper602 Funster
    Jun 23, 2013
    194
    87
    Teesside
    On mine, not the same make, when I lift the seat, there is a large 7/8" screw in cap but near that is a small 2/3" hand screw which on turning empties the water from the tank under the van.
  9. Tracey
    Dec 14, 2014
    4
    Cambridge
    On top of tank there is a large cap will try looking inside tank later. Thanks
  10. flatpackchicken
    flatpackchicken Funster Life Member
    Jun 27, 2010
    926
    897
    BICESTER OXFORDSHIRE
    On my ex Mobilvetta Kimu my drain tap was beside the tank under the seat, had to look very carefully as could hardly see it but was on the outside of the tank between the tank and the inlet pipe could feel it more than see it and turned it and tank emptied underneath the van under tank and nowhere near my grey waste outlet, good luck Regards Garry Flatpackchicken
