New Tarmac drive (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
I've just had a beautiful new tarmac drive laid. It's been a bit hot lately... and have discovered that my Autotrail Tracker has left 2" deep holes for each wheel where it has been parked. I hope it will sort itself out again over time but any thoughts on what I might use to spread the load? Two 12 foot long builders planks might do I suppose but wouldn't look too good. Could paint them perhaps? Ideas?
Many thanks, Jerry
Jan 3, 2008
3,337
5,356
Pakefield, Lowestoft, Suffolk, UK
Looking
How about contacting the people who layed the drive and asking them to put it right, or explain why it sank, or explain why they didn't tell you to keep your van off it for a while.
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
I think 3 and a half tons is bound to do this. It is hot and it's been laid about 3 weeks now. I need something to spread the load.
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
I'm with Iandsm on this one, first think I'd do is contact who ever laid it. I'm sure if you parked on the road on a hot day it wouldn't sink.
If no joy from them I'd go with your idea maybe a couple of scaffold planks would do the job.
Apr 9, 2014
1,307
6,596
Lincs
We had ours newly laid about 2 months ago, we put some plywood sheets under each wheel (about 2 ft x 1ft), thinking to spread the load. partially worked but not 100%. As there is a slight slope we put some cut down scaffolding planks on top of the plywood on the driver's side this side virtually no visible impression on the tarmac, but just the ply wood there is a slight impression. Unfortunately the MH is parked on the section with the thickest tarmac.
The plywood definitely helped spread the load.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Sounds to me like they have not done a propped job . A properly compacted sub base ,a base course ,then a top layer of Tarmac,should be good for 3.5 t
A lot of 4&4 weigh around this and as someone who's in that line of work I'd say they've skimped somewhere.
The way to check is to cut a small hole to check Tarmac thickness and stone depth.
Vlad
5,543
18,773
Mobilvetta Euroyacht
1996, then break 'til 2011
Have to agree with the others - job not done properly
PP Bear
7,802
28,749
Kent, UK
Auto Trail Dakota SE
Hopefully it was a reputable company who would want to stand by their good name and they'll sort if for you :)
Not Itinerant's I hope. Did they try to sell you a dog, arrive in a caravan and still wore wellies even at 30*C :eek:
rolandrat
436
258
Lancashire
Hi Top
When I had the parking area for the motorhome relayed I specified reinforced concrete with thick steel mesh, it was quite expensive at the time but worth every penny. No more deep ruts and it's easy to maintain.
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Thanks to everyone for the helpful advice. It is a very good company and I have been in touch and the MD is coming out next week having promised to "sort it". I like the idea of the paving slabs I have to admit. Probably embed themselves in over time...
43,323
49,430
Save the wait......while the tarmac is still soft mark out the dimensions for the four slabs, carefully remove the tarmac and drop in the slabs.....or ask the tarmac guys to do it as recompense for a crap job originally.
That way they wont look out of place.
rolandrat
436
258
Lancashire
Hi Top
If you are going to use paving slabs they need to be put on a solid base or they will definitely crack that's why I went for reinforced concrete. The weight of a motorhome being parked for any length of time on unsupported slabs or tarmac will cause cracks which rainwater can seep through and soften the ground further.
Vlad The Impaler
1,633
2,227
Rutland
I have to disagree I've done a fair few driveways for better off folk who park horse-boxes on theirs!
Several years on no ruts or cracks.
Vlad
Aug 27, 2009
19,788
23,069
Hertfordshire
Van Conversion
40 years
A friend of mine had his drive tarmac by paddy who was doing a job up the road and had some materials left over. It looked so nice he thought he would clean his windows. He climbed 4 rungs of his ladder yet he was still at ground level. True story.....:)
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
If you are going to use paving slabs get "municipal" standard ones, which are much thicker than the things your local garden centre might sell.
Apr 13, 2012
5,543
18,773
Using paving slabs is a bodge........shouldn't be needed, will look a mess and will probably crack and sink anyway
Scout
3,959
121,136
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
whe I had mine drive bricked (differant I know) I had to have the lagwer deeper biricks used for lorry parks, 80mm? I seem to recall not the 50mm used for normal drives
