New Rooflight (1 Viewer)
gazzeroo
63
5
Norwich
I`m a newbie
Hi all, I am looking for advice again! I need to change the rooflight in my Compass drifter. The one in it now has been completely sealed by a previous owner and I got a drip on the head when I was driving the other day, so have decided to replace it. Could any of you generous people recommend a replacement rooflight, it is a 400mm light, with a handle on either side that you push up to open. I do not necessarily need to replace same for same. I just want a good quality one that will work ok and not leak. Could you also recommend the best sealer to use as there seems to be differing opinions as to the best one. I have seen mastic on a tape, is this any good. I am a competent diyer so shouldn`t have any problems replacing the rooflight. As always I am sure you will help me out and I thank you in advance
Cheers Gazzeroo
rolandrat
436
258
Lancashire
Hi Top
Omnivents are very good but to keep the mechanism from seizing up it's advisable to spray some silicone lubricant on regularly.
43,319
49,401
400mm x 400mm is a standard size so any will fit.
When you remove the old one have good look at the wood battens which form the opening in the roof.
If they are black and spongy, which they may be if its leaked for a long time in the past, they will be rotten and need replacing.
Reactions: f6c
