New Rapido 10000DFH, Alde Heating 3020/3010 Issues (1 Viewer)
Floydster
1,063
2,754
Where ever I lay my hat
Van Conversion
A lifetime
I'm a bit confused about the 12v pump option, our circulation pump (top left circle with 2 arrows) automatically comes on when there is demand for heat.
Edit: we haven't got one in the header tank
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
I have hot water so i know thats ok, i am assuming if i have selected 3kw on electric i dont need the gas set to on, is this correct?
I will have a look for the other setting you mentioned.
only if you are on ehu ,you dont need both on at the same time
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
If you want it to heat up quickly select gas and 240v.
Martin
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
i suppose that will depend on the age of your system ,Alde seem to upgrade quite often
Z
zac
2,582
1,799
Basingstoke
Rapido A CLass 10000
since 2013
It does take a while to warm up , if i think im going to need heating whilst i drive i turn the heat exchanger on ,the control is at the side of the steering column ,there is also a fan unit under the seat next to the galley ,thats the booster unit and can be turned on from the square panel
Ah so i do have the heat exchanger as i have a control by the right of the steering, so if this is set to high then there is heat going into the back of the MH, i have found the blower under the L shape seats, i can get this to work ok.
Z
zac
2,582
1,799
Basingstoke
since 2013
Martin
I dont have an option for 240v, i can do the gas though so will try that tomorrow.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
The heat exchanger is Brill ,wack it up ,you can feel the heat on the soles of your feet
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
That's because you have set it to be controlled by the the thermostat so the boiler runs hot and the pump cycles as you say "on demand" there is also an option for continuous pump operation and the heating is regulated by regulating the boiler temperature so you get even more even heating with no on/off cycles But on ours certainly you don't have continuous HOT water only at the temperature set by the thermostat.
Martin
Floydster
1,063
2,754
Van Conversion
A lifetime
I'll leave this to the laird as he's got a Rapido so his controls will be more likely to be like yours.
Good luck and enjoy your lovely van.(y)
Z
zac
2,582
1,799
Basingstoke
since 2013
appreciate your help
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
It takes a bit of getting used too , i only realise how much i forgot on handover when i went to try it all out , one to remember is the dump valve ,its under the sink unit , you can make ice with the freezer on gas setting
Z
zac
2,582
1,799
Basingstoke
since 2013
i rememberd the dump valve for the alde however i forgot where the fresh water tap was and went hunting, found it in teh garage behind a board at the back which nearly sliced my hand off trying to pull everything back to get in there. Most stupidist place ever for a fresh water tap. Still i am learning:)
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
oh yes that one is a sod to get to ,i still find things like bleed valves for the heating system , have you put self levelling jacks on yours?
Reactions: zac
Z
zac
2,582
1,799
Basingstoke
since 2013
Mick from SAP did my E&P's last week, went to get it Friday, where i live at the side of my house is on an incline so they wouldnt level on there own. Once i made up some blocks to put under them (18mm ply with 3x2 screwed to them, Mick gave me the info). I can now level using manual at home. The wheels are quite a way off the floor though on one side.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
the jacks are IMHO the best extra that i bought ,if im on grass i put the jacks down ,i use spreaders under them,so far ive not got stuck on a grass field as you dont get the indentation from them ,i parked it up in Galloway a couple of weeks back and a tugger just looked as the jacks came down and said with a grin on his face" you know how to make a guy envious dont you "
Z
zac
2,582
1,799
Basingstoke
since 2013
What type of spreaders? may need some if i am on grass.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Some people use a block of celotex foam insulation with a bit of ply stuck either side, I made some by stacking and glueing a couple of bits of 18mm ply and made them about 300mm square if you want them higher just screw a few lengths of 45x45 on top, you could of course buy the fancy plastic ones that are just made for the job.
Martin
Z
zac
2,582
1,799
Basingstoke
since 2013
Martin
So the ones i have made may do the job,they are a little bulky though but good for very uneven ground.
jumartoo
6,888
187,787
Alhama de Murcia, Spain
Hymer Tramp
Since 1994
@zac please give our condolences to Salli on the loss of her mother.
Hope you get your motorhome problems sorted out, rather too high tec for us with our old Hymer! But plenty of experts in here to help.
Z
zac
2,582
1,799
Basingstoke
since 2013
I certainly will Judith. I am thinking it is just me and it is working but didnt know that till the folks on here helped. Always a wealth of information.
Jenben
2,224
204,353
Uk
Hymer Exsis I
Parked next to your van at SAP earlier this week @zac , very impressive looking van . Ours looked tiny next to it !
Z
zac
2,582
1,799
Basingstoke
since 2013
Well I think the heating is working as set it over night to 14 and it is warm in this morning. I think I was expecting instant heat but I can get that from the blow heater under the seat till it warms up. First outing end of week so will soon find out for sure. The underfloor heating is amazing. Makes our Delaware seem more like a bloody fridge lol.
Thanks for all the replies.
