New ideas or inventions
Discussion in 'American RV's' started by Boo, Mar 13, 2009.
  1. Boo
    Boo Read Only Funster
    Jan 26, 2009
    636
    4
    Cornwall
    Here's a place to air those barmy idea's............or not as the case may be :thumb:
    I'll go first :Wink:
    I have an idea to make a vaccum system for my R.V.
    I bought the most powerful vax and plan to fix it into one of the lockers.......then see if I can get the male and female connectors and use a Y joint to split it to 2, one port for the bedroom.......the other for the lounge......and make blanks for both.......then use the oringinal hose to plug into the ports..........that's it!! onboard vac :Blush:
    let you know how it goes :)
    Boo
  2. scotjimland
    Jul 25, 2007
    28,938
    25,625
    Nice idea.. but not new, it's already fitted to some up-market RVs :Wink:
    Look forward to hearing how it goes .. :thumb:
  3. takeaflight
    takeaflight Read Only Funster
    Sep 4, 2007
    256
    Stratford-upon-Avon
    Heres a barmey idea,
    Get the wife a nice pan and brush :Rofl1:
    I know I keep banging on, how about get the law changed so I can use one of these.
    Tow Dollies - Kar Kaddy SS on Sale
    Just an idea
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,010
    5,305
    Wirral
    Dehydrated water saves weight in the van:RollEyes:
  5. IanH
    IanH Read Only Funster
    Apr 6, 2008
    159
    3
    Cornwall
    I have a Dirt Devil central vac system in the 5th wheel,and for the brush brigade there is a slot that you open with your foot then brush the dirt into the vac.Both openings contain a switch that turns the vac on when opened.Much better than the portable vac i had in the travel trailer,
  6. gazz
    gazz Formerly "gazznhelz"
    Mar 16, 2010
    142
    Eastwood, Notts
    i know it's been over a year since this was posted, but i'm just reading thru the rv section,
    i did something similar to my van about 6 years ago, i bought a bagless pull along hoover, some 50mm flexi pipe (used for sludge pumps) a Y piece which is a guttering downpipe item, and a couple of central vacuum trap doors with contacts, and a 3 meter hose and wand with turbo brush,
    i put the hover in one of the lockers, the hose connection facing the rear wall of the locker, allowing the dust pot to be removed from the door end,
    hole in the rear locker wall and connected the hoover inlet to some pipe, then the Y piece, one branch goes to the front of the van, the other to the middle,
    the hoover is then left switched on at it's main switch, and the power cord goes thru a relay, which is fed 12 volts via the trap door contacts, when the hose is plugged in, the metal end shorts the contacts, allowing the circuit to complete and switching the relay,
    so the hoover starts up just by pluging the hose in a socket if on shore power or genny, when dry camping i turn the inverter on first, and stops when the hose us pulled out.
    the middle socket lets me reach the whole van from bathroom to the cab bulkhead, the front socket allows me to do the cab or i can stick the hose out the cab rood and hover the toad.
    a hoover hose holder from ikea in the bathroom keeps the hose and wand stored neatly, the wand is the one that came with the hoover as it's extends from it's self, the hose is from a central vacuum company as are the trap doors.
    total cost was about 70 quid, most being spent on the trap doors and turbo brush,
    i did have a couple of battery powered hoovers in the van before i put the centeral vac system in, but they just couldent cope with my dog's rate of hair shedding,
    it pulls 150 amps when running off the inverter, but it only takes 2 or 3 mins to do the whole van, so not much in reality.
  7. johnpengers
    johnpengers Funster
    Nov 7, 2009
    333
    412
    Somerset.
    Hi Boo,by the time you've plugged it in and unplugged it you could have run the hoover round in the traditional manner,ie, the wife :Rofl1: Atleast it will keep you out of trouble fixing it all up !!!!
    Regards,John P.:thumb:
