New Gas tank regulations?
Discussion in 'Motorhome Chat' started by Wildman, Jan 27, 2012.
  1. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    copied from another thread
    Can anyone elborate please?
  2. laneside
    laneside Funster
    Aug 14, 2009
    3,588
    5,625
    Oradour sur Vayres
    I need to phone a friend who used to do gas conversions on cars but he is not in.
    As far as I remember all the tanks came with a test certificate and I believe they had to be re-tested at a certain time scale similar to a receiver on a compressor but possibly not on an annual scale as per compressors
    I will find out though
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    if you have a Gaslow system fitted it has a lifespan of 15 years before it should be tested
    • Like it Like it x 1
  4. scotjimland
    Jul 25, 2007
    28,977
    25,675
    Found this ..
    "Although static LPG storage tanks and proprietory gas cylinders ('bottles') have manadatory test periods (Ten years and Fifteen years respectively), Automotive LPG tanks are not subject to these checks. It has been assumed that any Automotive LPG tank will be scrapped along with the vehicle at the end its life, which is Ten years on average. ."
  5. spannermanwigan
    spannermanwigan Read Only Funster
    May 22, 2008
    394
    207
    wigan, lancs
    Right on the button sir:thumb:
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,623
    3,453
    Telford, Shropshire
    There are no new regulations that I'm aware of, certainly not any that would mean the dealer has to decomission and remove a bulk tank. I am aware of at least one motorhome and caravan workshop that insists you remove your gas bottle BEFORE submitting your unit to them for a hab inspection, I've often wondered how they test the gas appliances without a gas cylinder. Perhaps its a condition of their insurance that they don't have "live" gas cylinders in the workshop.
    D.
    • Like it Like it x 2
  7. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    Am wondering how many old Yanks are running around illegally then Jim. Most if not all Yanks have an LPG tank. Just another get-out clause in the event of an insurance claim.:Sad:
  8. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    From comments on this and my other thread (where I explain what the salesman told me) I am going to ask them to explain why they have said they have to remove or decominish it.
    As I explained on the other thread, I am pretty sure when opening the outside lockers there was one that was for two gas bottles it had pipes but was empty. The salesman did say we just needed to get bottles from Calor so I guess that confirms that.
    So, assuming the gas tank is fitted elsewhere, if it stays and is working, would we still be able to use bottles as well and just switch between the two systems?
    I only ask because from the little bit of info I have picked up re gas, bottles are better at home and a tank abroad, or have I got that all wrong?
    How much cheaper is it to use the tank rather than bottles?
    Just need to get my arguments ready as to why they should leave it.
    Steve
  9. Jim
    Jim Ringleader
    Jul 19, 2007
    26,840
    79,215
    Sutton on Sea
    Steve, a tank is much better than bottles and tanks are expensive to buy and get fitted. They may be pulling a fast one and removing to sell on or fit elsewhere. Tell them you want it and are prepared to get it checked independently. :thumb:
    • Like it Like it x 3
  10. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
    Thanks Jim, don`t suppose you (or anyone) can give me a ball park figure for getting one fitted. I appreciate there are probably lots of variables.
    As it has been a week, just wondering if they will try and say they have already removed it.
    As I have only paid a `refundable` deposit, i still have a little bargaining room.
    thanks
    Steve
  11. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,827
    9,040
    Tropical Bar,Benidorm.
  12. scotjimland
    Jul 25, 2007
    28,977
    25,675
    Yes indeed Dave, the RV I sold will now be 15 years old.. not just yanks, lots of old euro vans have them .. and they are normally under-slung and unprotected from the constant spray from the road.
    I cleaned and painted mine once a year but that is really only a cosmetic exercise.. after 15 years corrosion will also be present inside the tank.. it would certainly be prudent to remove and have it cleaned, inspected, hydro static pressure tested and re certified.. but how many will .. it may be cheaper just to replace.. ? Either way it wouldn't be cheap ..
    As you say, in the event of an accident caused by a tank rupturing I think the first thing they would ask is, when was it last certified.. where is the test cert.
  13. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,174
    14,067
    Heavan
    depending on size, you are looking at between £400 - £600 or as much as £800 depending on size and ease of fitting.
    I reckon as said in your other thread, the dealer knows there's at least 2-3 hundred pound for taking this off and sticking it on ebay.:thumb:
  14. Encantador
    Encantador Funster
    Jul 2, 2011
    835
    312
    UK
  15. CazPaul
    CazPaul Funster
    Jun 30, 2011
    326
    197
    Durham
    To fit an underslung tank at Autogas 2000 in Thirsk is around the £750 mark, there is hardly any difference in price between a 40 litre one and a 100 litre one so its best to fit the biggest one that space/payload allows.
    Paul.
  16. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,678
    14,531
    North Lincolnshire
    Spot on, JIm.
    The maximum life for an LPG Cylinder (and these are cylinders, not true tanks: capacity determines cyl / tank, not what folk want it to be) is 10 years, extendable to 15 on certification. After 15 years a full technical inspection is required to re certify.
    This is not "new" legislation, or designed to "take more money off us", it already exists, has done for years.
    There will be some coming on now telling us they have had / used these things for 500 years without any problem: sorry, but that's how it is.
  17. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    I would ring one of these companies that fit the tanks and ask them if there has been some new regulations as they would be the first to know (it being their business). Most sales managers know nothing about motorhomes other than the vehicle specs and how well their sales team has done this month. I doubt very much that one would know about some new regulation re; gas tanks -most of them dont even check /advise someone about the correct licence entitlement to drive the motorhome they would like to purchase if its above the 3500kg base weight
