- Apr 18, 2009
- 3,569
- 3,367
- Hymer B584, A Class
- Not long enough!
Your not from Yorkshire are you? I don't seem to understand a word your saying but words and pics are good and I'm sure the story will only get better
Not on this one project no. Each resistor costs a fraction of a penny. So rather than just ordering each value as I need them I ordered a bulk load of 1460 of them in one go.Jeez I thought you said simple?? are you gonna use all those resister thingys??
Thank you...Good luck Gromett, the fun begins.
An interesting aside, that temperature controlled fan http://www.ebay.co.uk/itm/Arctic-F12-TC-120mm-PC-Case-Cooling-Fan-Temperature-Controlled-Silent-Quiet/182257356550?_trksid=p2047675.c100008.m2219&_trkparms=aid=444000&algo=SOI.DEFAULT&ao=1&asc=39060&meid=4bb7b834cdd94a64806f87bf39b374b2&pid=100008&rk=2&rkt=5&sd=182288768003&clk_rvr_id=1107436610887&afsrc=1&rmvSB=true could always be fitted with a series variable resistor in the sensor (thermistor) and thus change its range
Of the two solutions, I far prefer your project, which is well considered, well specified and will be gratefully implemented in our own M/H
Not for me and not in this particular use case. The fan needs to be off below a certain temperature and off if the ambient is above a (variable) temperature if it wont' have any effect. For the range in between it needs to run at a speed low enough to minimise power usage and noise issues but also have the maximum effect. It is an unusual use case for fans in that an increase in temperature doesn't always result in a higher fan speed.I suppose a var resistor in series with the probe wouldn't help?
Why? I only need 2 inputs and 1 output. The ATTiny85 is only 97p each. The Nano is a couple of £ each and I wouldn't use half the features on it. Plus the nano is bigger and draws more current.... The 328 is overkill for this I think.Thought you might have used the Nano, Grommet.
NO, NO , NO, I appreciate that it is not worth you making them for people.I have some concerns about building them for other people
I could probably do something along those lines. Although I am a fulltimer and I tend not to park near a post office most of the time so I would need to do them in batches.NO, NO , NO, I appreciate that it is not worth you making them for people.
What I asked is, would you be able to program the microprocessors for a few of us for a fee. Perhaps supply the processors to us at cost plus time plus postage and a bit to contribute to the cost of the development gear you have bought, if that is realistic. There would then be no comeback on you at all. We could pay you through PayPal if you have an account.
I would enjoy making up the circuit myself and installing it. Which of course would be totally my responsibility. But programming the processor would not be practical.
I have a breadboard and a large bag of resistors, voltage regulators, transistors and diodes from my late brother so may already have a great deal of what I need.
Steve
Thanks Gromett, please put me down for a programmed processor when you are happy with the result. My current set-up will be fine for the winter trip to Spain as long as I remember to switch it on.I could probably do something along those lines. Although I am a fulltimer and I tend not to park near a post office most of the time so I would need to do them in batches.
Me too please Grommet, I'd be grateful if you'd add me to the list as and when. Cracking idea.I could probably do something along those lines. Although I am a fulltimer and I tend not to park near a post office most of the time so I would need to do them in batches.
If it's an absorption fridge at an ambient temperature of 40C its going to be running continuously I think. A compressor fridge might be different though.Thank you...
I had looked at your link before. The problem is at an ambient temp of 40C the fan will spin full speed all the time, even if the fridge is down to temperature and no heat is being generated at the back of it. That is why I am using two temp probes to work on the differential.
Are you not measuring the absolute temperature anywhere and only the difference? If so is there not a danger the fan will be running when it doesn't really need to? For example, if the ambient temperature is 15C and the fridge starts cooling, conventional wisdom suggests a fan isn't required but if I understand your design the fan is likely to be running, albeit fairly slowly and not really doing a lot. It could also turn on if the ambient is even lower.
too expensive Got my eye on a few options. will post more later.What about a Mornsun dc/dc regulator or similar ? They have efficiencies around 85% and no load currents of a few mA?
I am currently looking at either buying a premade unit like this.What about a Mornsun dc/dc regulator or similar ? They have efficiencies around 85% and no load currents of a few mA?
I also need to find the best way to provide a stabilised and regulated 5v supply
The nano has a linear regulator on it not a dc/dc buck converter. It will operate off 12v but is very inefficient. It's recommended voltage is 7-12V but your battery may hit 14.5V which may cause the regulator to overheat in prolonged use. It uses an UA78MO5 according to the circuit diagram.The Nano already has one on. No idea if it will provide enough current for your needs. Whats your power budget?
Good luck with the project. Nothing like a real world project to practice on. After developing embedded 8 bit micro projects for the last 30 odd years I've learnt to always budget for a couple of extra I/O pins. It almost invariably ends up that you need them for those little extras (or someone else....usually the marketing department.....asks for something else halfway through the project).
