new engine (1 Viewer)
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
well I have the engine from wales I will be doing nothing more than changing the cam belt kit and the oil filter putting the turbo and manifold off the old engine new gaskets as the guy had sold the turbo then back on the road for next week at latest week after ::bigsmile:
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
just had to put it in the car side door as when I went to bring the trailer Frome my son's house the tyre was flat bummer co we just put it in the kia
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
a quick rub down and coat of paint wouldn't go amiss, well done Bill I do hope it's the last one you have to do. Time you actually got some use out of a van. so good luck with it.:thumb:
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
If the engine has been stood for some time I would take the opportunity to change the water Pump and Water jacket plugs whilst it is out.
43,323
49,427
regardless of what the seller said, i reckon its been stored outdoors.
Change the alternator and belt and wire brush the front pulley's Bill.
If you fitted a new clutch on the last one i would change that as wel....a bit late when the engine is in and clutch slips.
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
as that engine sure looks like its been sat around for some time . while its on the deck, would you not think it wise [for the price of a head gasket /bolts] to remove the cylinder head and check the valves and cylinder bores before you go any further ? not a critism just a observation . regards garry
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
what Engine is it??
?? I GOT A WARRANTIED complete fully reconditioned Engine from London
for my pick up L200 dont get me wrong it was £1300 but that incl £200 deposit for my old Engine, the whole Engine Block is re done all moving parts is new valves cams top and bottom, i got my turbo reconditioned and my fuel pump done as well , new belts pulleys wheels complete , Engine on a pallet delivered and old one picked up when i was finished with it,,
Now drives awesome like new, I got an Engine that had been sitting similar to the above in good faith it was taken as working,, Ended up cracked Linings ,i stripped out from the old van and traveled 50 miles for it , no warranty and even if there was i was so pissed off i swore i would never buy an Engine that way again , Trusting that an Engine is good to go is taken in good Faith ,the seller its nothing for them to sell sh8t , there not spending hours stripping and building and adding on all the new parts around it, Then it mangled,, strip it down clean it up and add new gaskets to what you have,
Good luck hope it goes well , :thumb:
  • 1356002163_466311401_4-Mitsubishi-reconditioned-l200-engine-25-4d56-t-diesel-remanufactured-engi.jpg
43,323
49,427
agreed.....VW Golf engine from a breakers.(100 mile round trip)
He said it was driven in and ran well.
Slotted it in and started up.....more smoke than the Vatican chimney on new pope day.
Got a refund luckily and they collected the palleted engine.
JockandRita
11,462
150,098
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Bill, you're a braver man than I.
I really do wish you well with that [STRIKE]wee [/STRIKE] project. :whatthe:
All the best with it. :thumb:
Jock.
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
changing all the ancillary's going to have a look inside tomorrow it will have a good cleen up and putting the water pump of the old engine ont it and before it gows in it will get a bench run compression test
43,323
49,427
well I have the engine from wales[HI] I will be doing nothing more than changing the cam belt kit and the oil filter putting the turbo and manifold off the old engine new gaskets[/HI] as the guy had sold the turbo then back on the road for next week at latest week after ::bigsmile:
i did think that was very unlike you Bill.
I though maybe frustration had beaten you down. :roflmto:
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
I have new hed gasket kit on order and it will get a scim to will be changing prity much most of the ancillary bits and clutch
bill
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
did have a bit of a frustration fit but just got in frome the garage just now it is mint inside valve sets looking good head back on Tuesday f
my son had the heed off in half hr.
that's why I posted it to get another view sometimes you cant se the trees for the woods
thanks john :thumb:
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
the ting is I do know the guy and I know a bit of history he has helped a few on a another forum i even know the van it came out of i know it was running when it got laid up owing to a ger box problem been pestering him for week's to get the engine off him i know the risk but i have the ability to do the work required
and it would be £1900 to get a rebuld plus vat looked in to it that's if thay could find one thanks for posting
bill
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Was that price for a full unit, or a half engine,,,(no head etc)?
MikeD
3,936
3,697
London
IH PVC
Since 2012
Bill
Pleased you got her home ok :thumb::thumb:
Only a little way to go now ::bigsmile:::bigsmile:
Mike
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
progress so far this week
Removed old engine striped down the engine I just got cylinder boors spot on clean and no rust or corrosion bit of a mark shadow where pistons had been siting.
I just gave them a squirt with WD 40 pistons cycled engine a few times marks almost gone ::bigsmile:
rebuilt cylinder head full Monty valves reground valve stem seals re shimmed put back on engine
  • Changed over water pump thermostat housing the thermostat is almost new from last rebuild replaced all hoses
  • All pulleys changed over
  • Replaced power steering pump and pipe work modified
  • changed alternator over
  • clanged out fan belts
  • new cam belt kit to fit tomorrow it only came today to the motor factors.
  • gear box serviced
  • clutch removed will change over flywheel tomorrow
  • camera stolen off garden wall :cry:I left it on the wall when I went for dinner:Doh:
MikeD
3,936
3,697
London
IH PVC
Since 2012
  • gear box serviced
Bill
I don't know whether to say "like" to all the work you have done or "Oh cr*p" to the missing camera.
But decided overall - what a great job you are doing :thumb::thumb::thumb::thumb:
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
Bill
I have had a grate time doing it was a bit mift at the start of the week but had a few challenges with it the weather has been on my side.
It got lovely and warm at the front of the garage today only got one black nale today when I dropped the power steering pump on my big toe:shout:
the only thing abut losing the camera was losing all my picks of the rebuild:cry:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Bill, You dont need me to tell you to rebuild it. Take nothing for granted :thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I think you deserve some sort of Funster award Bill for getting on with things no matter what s@ hits the fan:thumb:
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
well the gearbox going on tomorrow but I wont get it back in th van till the weekend as they sent the wrong cam belt kit
Wildbill
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
just got to change cam belt kit now and in it gows :wooo::wooo:
JockandRita
11,462
150,098
Lincs/Cambs border
N+B Flair 8000i
ah but does it go as far as the post office:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Roger,
If Bill says it's a "goer", then it's a "goer" regardless of whether there is a bl##by Post Office about or not. :Doh:
Give it your best Bill pal. :thumb:
Cheers for now,
Jock.
