New Driveway for Motorhome (1 Viewer)
Diamondcub
52
29
Basingstoke, Hampshire
4 years
I need to have a driveway constructed for my Motorhome, the area is quiet large so I was wondering if anyone has had any experience with laying a couple of strips (concrete?) for the Motorhome and for the rest using fleximas type ground reinforcing mats? So the grass can grow and drainage maintained but i could also use this area to park my car. Do any caravan sites use this on their sites?
Thanks for your advice
Allan & Loren
1,736
2,630
Leyland, Lancashire
Autotrail Dakota
Since 2014
We used grid force for our drive for our rv. Laid a solid compacted hardcore base then laid the grid force on top securing each one to the other and periodically securing into the base. We then filled with gravel but you can lawn seed it. It's used a lot by councils and commercial businesses. Our rv is 7.5tonne and the drive is fabulous.
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
We stayed on a Dutch camp site
Where they had done that on each pich.
Worked very well.
Our friends also did this at there house.
They dont have ant problems.
Diamondcub
Diamondcub
52
29
4 years
Thank you Allan I will give them a call
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
My Bolero stands on 2 concrete strips with shingle in between, beside our bungalow, my car stands behind it.
Apr 13, 2012
5,544
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
You obviously need some Tarmac..... I happen to have load left over from a job........ can do it cheap.......... for cash.............
Allan & Loren
1,736
2,630
Leyland, Lancashire
Autotrail Dakota
Since 2014
We bought ours from a local builders merchant as they had a good price.
. We did it about a year ago now and the gravel has settled so needs a top up which we will do in the spring.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Currently in the process of converting our frontage for parking... Using the self draining ground reinforcement method....
The Moho parks where the spoil heap is...
Diamondcub
Diamondcub
52
29
4 years
Scout
3,959
121,224
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
when I had my drive done I got 80mm driveway bricks from marshells of off ebay, they have a shop on there for B grade stuff thier clearing
Fletton
1,531
2,501
Lincolnshire, UK
Wow that is some groundwork, a much bigger job than I was anticipating. Did you use a driveway contractor
The "contractor"... Is..... Li'l o' moi..
Dug by hand ... The 14tonne payload lorry with grab - had to make two trips to remove the spoil heap !!..
The amount of "dig".. Spoil removal will depend upon the type of groung you have... Because it's the sub-base that's important for any "loading" ...
Also you "should" use MOT type 3 hardcore for self draining - MOT type 1 is the commonest... Type 3 is not usually stocked at local merchants etc...
Type 3 has reduced "fines".. If you live in an area that requires SUDS, or sustainable urban drainage systems - it's a must.. ( we don't but i'm still using it) see @grasscutter 's post above.. regarding the Regs in some areas..
Diamondcub
Diamondcub
52
29
4 years
Thanks for the advice on the sub base.
I will get my shovel out later
No, come to think of it, does anyone know of a good man near Basingstoke
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Our local Council has a web page devoted to new driveways with helpful advice and regulations.
I think the surface geology in the Basingstoke area is sands/gravels. If so, you should be able to use a reduced thickness of subbase. However, it may be advisable to lay a geotextile (such as Terram) on the subgrade before laying the subbase.
TerryL
6,184
8,186
North East
Low Profile
Surprised no-one has raised covenants. I know you park your car there but ensure there are no restrictions on parking caravans/large vehicles with either the local council or your property deeds.
