New Battery? (1 Viewer)
Clickem
1,034
1,073
Northumberland
None
7 years
Have a Transit based van, about 3 years old, that sits on the drive on permanent EHU. Took it for a run about 4 weeks ago and also found the vehicle battery was low on electrolyte, on 2 or 3 cells, so topped it up
Will not start this morning and voltage about 11.2, went up to 11.3 when charger switched on. As the Hab battery is showing over 13V, I am assuming that the charger was turned ON and is working OK
Is it safe to assume a new battery is required, or are there other things that I should check?
Any pointers as to best place to buy - in no hurry?
TIA
Jul 13, 2008
3,738
3,849
Low profile
Most car parts suppliers will have or be able to get you a battery, go for one with a 2 year guarantee.
funflair
19,330
30,167
Guisborough
MORELO palace
since 2012
Do you know that the starter battery gets charged when on hook up.
Martin
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
Martin
Been on this permanent EHU for a couple of winters now, and had no probs, so believe both batteries are charged. Battery would have been drained by alarm and other parasitic drains, many times, if it was not being charged
Coming to conclusion battery is US, priced a new BOSH. Left on charge overnight and will check voltage tomorrow. If still low will go for new battery
43,319
49,372
With the charger turned on, and IF it charges the cab battery, the voltage should show a minimum 13.6v.....whether the cab battery is charged or flat.
I would consider checking the charger first to confirm it charges both hab and cab batteries.
Clickem
Clickem
1,034
1,073
Northumberland
None
7 years
Thanks for that. I have taken the battery out and got clearer readings, much higher when on charge. With a Transit you have to remove the seat and the swivel to get to the battery. My first readings were in situ and from a clamp on a clamp
Replacing with a sealed battery - sick of taking seat out
