New batteries - what do you think (1 Viewer)
Apr 8, 2008
107
18
Snaith
Nineteen years
Battery Megastore – Leading Supplier of Leisure Batteries in the UK
Offering the CHEAPEST batteries all at the HIGHEST quality!!
THE BEST ABX AGM BATTERY AROUND
**New Technology**
The name of this battery is:
AX 595 850
Battery Spec:
· AH – 95
· Cold Cranking - 850
The size of this battery is (dimensions):
· Length (mm) - 351
· Width (mm) - 174
· Height (mm) – 190
· Terminal Type – Right Positive A
This battery is suitable for:
Caravans, Boats, Cars, Leisure Use and Much more. This is a Heavy Duty AGM battery !!!
This battery has a warranty of:
5 YEARS
This Battery Cost:
£124.95
Battery Description
These batteries are IDEAL for people who rely on battery use in their motor home, boat or Caravan. They are extremely durable and can be installed at any angle to give you super flexibility. These batteries are heavy duty and require no maintenance, and are completely safe to store in your caravan / motorhome at any angle.
These batteries also have a huge cranking capacity, and are ideal for cars that are specialist or high end, or cars that aren’t regularly used.
· AGM separator
· Outstanding cranking power
· Completely spill proof
· Can be installed at any angle
· Increased performance rate
· Longer battery life than standard batteries (new technology)
· Valve regulated vent plug
· Reinforced casing to protect from vibrations
· Superior starting power even in the cold
· Twice as durable than flooded MF Batteries
Battery Megastore are the number one importers of batteries in the UK, this allows us to pass on mega savings to our customers for these top end, high quality products. You wont find these products on Ebay any cheaper than with us, as our summer promotion has reduced 20% off all Motorcycle, Car and Leisure Batteries!!!
Whether you are looking for a battery for your Golf Trolley, Caravan, Boat, Car, Mobility Scooter, or Tractor we supply them, and we have a technical team on hand between 8.30am until 5.30pm Monday to Friday to answer any questions you may have, or to advise you and help you locate the correct battery
scotjimland
2,309
9,979
A Woosh bang
Personally I would't buy AGMs (Absorbed Glass Mat) or GEL batteries
'Bang for your buck' , cheap FLAs ( flooded lead acid) are hard to beat ..
Some general information on care and maintenabce of all types here http://www.phrannie.org/battery.html
worth reading before deciding ..
goldwinger
Apr 8, 2008
107
18
Snaith
Nineteen years
Sorry for the slow reply takes a while to read all that info Jim, very helpful, we have a hymer554 and I want to fit two batteries and a solar panel, the battery already fitted is three years old and has had little stand along use, I have read that I need to replace with two new batteries, for to add a new batter and connect to the old one is not a good idea.
Looking as all yorkshire men do get the best for least money possible.
scotjimland
2,309
9,979
A Woosh bang
look no further, buy cheap FLAs .. good enough for the U Boats .. good enough for me :thumb:
On a serious note, I bought 4 x 85 cheap FLAs in 2005 .. IIRC about £30 each, and they were still going strong when I sold the RV this year.
Also, be aware of battery warranties .. they aint worth the paper written on because if you have a claim you will first have to prove that you didn't abuse it, almost impossible to do. Secondly, if they do pay out you will only get the pro rata value for the remainder of the warranty period, not a replacement battery.
I once asked a battery retailer what the difference was between a 1, 3 and 5 year warranty .. the reply.. the price .. no other difference..
If looking for good quality, no frills FLAs look no further than http://www.lincon.co.uk/
buy direct from them and cut out the middle man with the mask on ::bigsmile:
goldwinger
Apr 8, 2008
107
18
Snaith
Nineteen years
jim thank you again your a Funster diamond
