NEED HELP WITH MY GENE (1 Viewer)
DiddyDoddy
41
31
HI HAVING SOME ISSUES WITH MY GENE, IT RUNS FOR ABOUT 30 MINS THEN CUTS OUT CHECKED THE FUEL AND WHAT I CAN TO GET IT STARTED,STILL NO JOY,ITS A CLARKE 1KW INVERTER.
ANY IDEAS
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
May be a bit of (rap in the carb blocking the jet.. or filter (If fitted) may need a clean.. (y)
DiddyDoddy
DiddyDoddy
41
31
GOING TO GET THE TOOLBOX OUT SHORTLY AND HAVE A GO THANKS
Keef
33
13
Hereford
Low profile
15 Years
Please don't use all capital letters as it's considered to be shouted and rude
Feb 24, 2013
13,054
101,387
Bolsover, Derbyshire
Hymer S800
not long enough
Have you checked the oil?
We had a similar issue with ours some years ago, ours had an oil light which flashed when low, ran fine for 15 - 20 minutes then conked
Topped up with oil, been fine since, probably about time to check it again :D
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
Actually don't worry about the capitals it doesn't matter, some may say a broken gennie is always something to shout about..hope you get your gennie working (can't believe I've just typed that lol!)
Jun 30, 2010
7,924
27,228
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Yoy don't need a gennie:cautious: Set fire to it!:ROFLMAO: Toughen up Funster!:whistle:
cruiser
4,215
4,951
northampton
coach built elddis 400
since 1978
don't it can be used for the vac to
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
If you haven't run it for a while, then the possibility is that the fuel has evaporated in the carb, and left a 'film' which is slowing the fuel supply entry down from the needle valve. Remove the carb, clean out, including both the main and progression jet, and try again after adding a touch of new fuel to the tank. (y)
