need a soft floor repair in cambridgeshire area (1 Viewer)
Aug 10, 2012
834
881
cambridge
Globecar
since2001
hi
I have a soft floor in my CI 656 and need to have the floor injected from the outside/underneath.
could anyone recommend a mobile fitter/ workshop within 50 miles of cambridge that could carry out the work at a reasonable cost
regds neill
Geo
Trader - Funster
Jul 29, 2007
11,757
14,563
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
hi
regds neill
Me thinks your plan is Flawed "Gravity" dictates its injected from the inside:Doh:
Geo
buckby
213
147
nottinghamshire
coachbuilt
If you inject it in from above don't do what I did.
I didn't put enough weight on the floor after injecting it you need to put paving slabs on the area my floor kept swelling after I fitted the laminate in my swift I ended up cutting a square out of the floor with the vibrating saw then fitted king span in with silicone then re fitted the laminate floor never had a problem then hope this helps somebody.
Teddyj
35
139
St Neots
Since 2009
Need soft floor repair in Cambridgeshire area
Hi bubble63
I have recently,successfully,fixed soft floor on my M.H.I did the job From above,to do it from below IMHO would be a complete no no.Why must you do it from below?My autotrail had a fully carpeted floor with furniture fitted on top,I removed carpet from all of the central area, did repair and got self adhesive vynil planks from B&Q and the jobs fantastic,just need some loose rugs now.
Hope this helps.
Ted
bubble63
Aug 10, 2012
834
881
cambridge
Globecar
since2001
thanks for the input so far:thumb:
i have fitted vinyl , and loose carpets, but my vinyl seems to be attached , its the floor that getting spongy in the high tread area near the galley / bathroom
i have read of injection from below leaving the flooring intact. i guess you inject 'rods' of resin to sure up the floor
the installer drills a matrix of holes, injects and fixes the floor, just need a contractor to do it!
anymore suggestions :Smile:
neill
cambridge
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
You are still not addressing what made it spongy in the first place :Eeek: Are you sure you don't have a small weeping leak from either bathroom or sink area? Simply walking on the floor will not weaken it you have a underlying problem --If you are sure nothings amiss can you add some 3/4 ply from underneath (glued and screwed)? thus strengthening the floor in that area
terry
bubble63
Aug 10, 2012
834
881
cambridge
Globecar
since2001
I assume the floor is softening because it is in a high foot fall area and we are all large adults present
The floor is - top ply -70 mm polystyrene- ply
I assume the polystyrene is compressing slightly due to heavy traffic
Hence resin vertical injections will stabilise the sandwich
Hence injections from underneath and a request for a recommended fitter
I think some people may have de lamination, I don't think I have that , the floor is slightly compressing and I am keen to fix it early
I have read of others having this done, but I need a recommend
Sorry for the confusion but I don't think I have a leak, just Italian engineering
Neill
bubble63
Aug 10, 2012
834
881
cambridge
Globecar
since2001
bump
still looking for someone who injects from the bottom!!
i know its been done, just trying to find anyone who does it :Smile:
neill
camocam1
1,112
788
Elgin,Moray,Scotland
bailey approach 760 se
since 2012
Just to brighten up the thread I was at my local engineers the other week and the young guy was getting a right earful from the boss
I asked what he had done wrong and was told he was was sorting a delaminated floor in a MH and drilled RIGHT THROUGH the floor then tried to inject the hardener which ran out underneath
Boss not a happy bunny !!!
