NE 183 Control panel problems
Discussion in 'Tech/Mech General' started by skybluemarky, Apr 14, 2010.
  1. skybluemarky
    skybluemarky Read Only Funster
    Jul 20, 2008
    Hope I'm posting this in the right section. We have a swift sundance 590rl and the control panel is acting strangely. The display went like black blocks and you couldn't make anything out. I took the panel off and replaced the battery and whilst doing that found the contrast knob and turned that around. That improved the display and you can make things out better but it still looks strange. Been quoted £270 for a replacement, I was wondering if anyone had similar or knew somewhere that repairs them. It is a NE183.
  2. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi skybluemarky
    Welcome to MH Fun :welcomefunster:
    Sorry can't help with problem but someone who can is bound to be along soon.
    Best af luck.
    Dave :thumb::thumb:
  3. hilldweller
    Dec 5, 2008
    27,534
    26,621
    Macclesfield
    Maybe you can !
    Can you see any identification on the display? It's certain to be an off the shelf one so if you can identify it there's a good chance you could swap it - does it look like it plugs in ?
    If the panel functions correctly then it's probably the display or if you are very unlucky a bad voltage coming off the computer panel.
    Where are you - it always helps if you edit your resume (my profile) and give us some clues.
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,390
    5,417
    East Sussex 01-580-881288
    Hi skybluemarky
    This is quite a common problem.
    If you remove the panel again and disconnect the 12v plugs and replace them after 30 seconds you will find that this will sort this out for you.
    Any more probs you are more than welcome to call us.
    Regards
    JX Workshops
