Mystery box in engine compartment (1 Viewer)
barrywi
120
28
Cumbria
C class
I am a Newbie to motorhomes but have caravaned for years
Under the bonnet of my 1998 Autotrail Cheyenne( Boxer based) there is a mystery box about 31/2 by 21/2 inches and about an inch thick. There are 3 wires which enter it and it seems to be a plastic frame filled in wilth an Aradite sort of hard material. The three wires are red, brown and black with the black connected to earth by the battery.Cannot think what it could be unless it is connected to the alarm system. It is just hanging on the wires on the left hand side of the engineand goes into loom which may be the work of Autotrail. It does not look as if it was fitted when the van was made in the Peugeot factory. Any idea what it may be?
Steve_UK
37
17
Mid Sussex
Auto-Sleeper Clubman GL
Since May 2012
Hi,
Sounds like a Battery Master. See Link Removed
If so, it connects the leisure battery to the engine battery in such a way as to provide a small charge (up to just over 1 amp) whenever the leisure battery voltage exceeds that of the engine battery by 0.5V.
Especially useful if you have a solar panel keeping the leisure battery topped up while parked up for extended periods, in which case the engine battery is also kept charged.
The box ensures that the engine battery does not charge the leisure battery as that could lead to starting issues!
Hope that helps.
Steve
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
one like this Broken Link Removed
used one on my self build
with a switch on the live feed
to the leisure battery
:thumb::thumb::thumb:
