my tablet has died (1 Viewer)
Al-Di
3,056
28,745
prestwich
Eura Mobil A Class
since 2013
i can't get my tablet to charge after i let it get flat, charger has output 5v,
it wont take a charge when connected to pc through usb,
is it goosed
any options,?????????????
D
Deleted member 29692
How long have you left it on charge?
Sometimes if they get really flat they take a while.
Plug it in to the mains charger, not your PC, and leave it a long time - overnight if necessary - and it should kick start again.
Poohbear
280
473
Worcester
Swift Lifestlye 644
June 2015
Or change the battery, most are available on Ebay, and Youtube shows you how to swap them over.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Try another USB cable first, just in case.
Is there a light that comes on to show it's charging, and if so, is it working?
If the battery's removable, test the voltage with a multimeter and see what you get. Try charging it for a few hours then re-test it. No change? Time for a new battery.
Mar 23, 2012
9,524
31,957
sleights
c class
Ours did that if you leave it on charge for ages may be lucky loads of advice online I think its a common problem. If fairly new take it back!!
DBK
18,009
48,002
Plympton, Devon
PVC, Murvi Morocco
Is it Android? They vary but try holding the volume up button down as you plug the cable in, if that doesn't work try the volume down button.
What model is it?
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
One of ours did the same
Tried all the advice on the net re volume buttons, leads etc. Etc. Without success so then thought I'd try to back it up to pc to try & save the data & whilst trying that it suddenly started charging & has worked fine ever since.
43,295
49,275
Connect it to a wall charger instead of computer.
Wall charger will have a higher charge current than the usb on a computer.
You dont say what tablet it is but i had two kindles fail to charge...only a few weeks old and both exchanged by amazon.
Nov 6, 2013
1,414
3,156
S. Ayrshire
The usual
Since the beginning
Also...
It can sometimes take a little charging before a phone / tablet will reboot once the battery has completely discharged.
Charge it via a proper charger for a couple of hours, then try and fire it up.
Feb 14, 2009
1,373
3,325
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
We have a Samsung Tab 4 8" - apparently a common issue is if the battery is left to run down it wont charge or display - it has happened to me twice - the fix is interesting - and I have done it - you need to carefully take the screen out of the frame and remove the battery connector - then reconnect the battery and out the screen in and recharge it - strange but true....
Some others suggest that you plug the charger in, then hold volume up and down buttons down at same time for about 10 seconds and release after. Your boot up screen should come on and your battery should be low. Turn your device off and let it charge normally.
Apr 26, 2014
622
606
Thornton Cleveleys
2004 Bessacarr E735
3 years
We had trouble with a Samsung Note.
Not holding charge. Wouldn't go past start up screen.
I contacted Samsung and they gave a two year guarantee and this was 21 months old. They sent me a postage bag and repaired it and fitted a new battery all f.o.c.
Excellent service.
Al-Di
Al-Di
3,056
28,745
prestwich
Eura Mobil A Class
since 2013
sorry been a little busy with mum,
its an ebay special £60, about 14mths old,
been flat for approx 2/3 weeks(forgot about it)
will try as suggested with methods
I have left it overnight on mains charger, no change
thanks for all the help including @Tootles but cremation may be better:rolleyes::rolleyes:(y)
Minxy
32,623
66,460
E Yorks
Carthago Compactline
Just a thought - have you tried putting it into a warm place such as an airing cupboard etc to gently warm it up ... might help the battery 'want' to charge up.
Aug 10, 2012
838
891
cambridge
Globecar
since2001
I had the kids nexus do the same
my 'man' at work opened it up and he zapped it with an over voltage, been fine ever since
ps 'man'=comp-u-ter man;)
Al-Di
Al-Di
3,056
28,745
prestwich
Eura Mobil A Class
since 2013
its in the bin, beat it to death with hammer:sneaky::sneaky::sneaky:
bought a new one with gps(y)(y)
Minxy
32,623
66,460
E Yorks
Regardless of the cost I bet you really, really enjoyed smashing it up ... I know I would've!!! :D
Al-Di
Al-Di
3,056
28,745
prestwich
Eura Mobil A Class
since 2013
Oh yes it was a pleasure I hate techie things drive me daft,
