My Solar/Power dilemma ! (1 Viewer)
C
Chockswahay
We have had the van for over 2 1/2 years now and never needed extra power. However now we are back in Scotland the van will spend periods of up to 3 or 4 weeks sat on the drive. The problem is that over this amount of time the Alarm (I assume) slowly discharges the starter battery.
I can not have a mains lead connected all the time (neighbours!) or sometimes the van is just too far away from mains power :(
So my dilemma is how can I keep the battery from draining down yet still keep the alarm active?
I do not really want to mess about with roof mounting solar panels (question posted separately). I have wondered about smaller 'portable' panels propped up on the dashboard, but I understand that this will reduce effectiveness by up to 70% (?)
Also I believe I would need a Schaudt regulator to make it all work in harmony....
Does anyone have any practical advice please?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Scotland, low sun and not too much of it. So really you need as big a panel as possible. A small one in the window probably won't work even if you manage parking due south.
Our 100W roof mounted one struggles in Cheshire winter.
C
Chockswahay
That's what worries me! As it happens my usual parking does indeed face the sun but even then??????
(Hmmm...... what about a big panel stuck on the windscreen with suckers?......LOL)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
( Hmmm...... what about a big panel stuck on the windscreen with suckers?......LOL)
At a guess it would be at a very good angle, better than flat on the roof, measure up your screen. You'd probably need more than suckers, they are pretty heavy, a bit of 2x1 wood then.
Quite a few FUNsters carry a big panel and set it up on the ground. Fine but risk of theft and the problem of storage, setting up.
R
Robert Clark
Have you considered either?;
Fitting a B2B charger to keep the leisure batteries topped up when driving, plus a battery master to keep the engine battery topped up from the leisure batteries
OR
Connecting the solar panel to the leisure battery and using a battery master to keep the engine battery topped up
OR
Both of the above - belt and braces
scotjimland
2,246
9,754
A Woosh bang
As Robert said..
Battery Master.. easy to fit..
Jim's shop or eddievanbitz.. about 60 quid.
C
Chockswahay
Hi @Robert Clark
The issues are with the EBL99 on my van so not (easily) do-able. To be honest I only want to reduce the rate of discharge for 'peace of mind' and convenience.
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Ideal but not thief proof, I have a 20w panel on the dash in a car and it keeps the battery topped up all the time, and its not pointing south(y)
In fact south is about where my Hymer is in the first pic(y)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
eddie
8,142
41,174
Taunton Somerset
RV
since 1989
Hi @Robert Clark
What issues with the EBL? No point reducing he rate of discharge as the quiescent drain will be what it is, unless something is faulty.
Many people,stand in their Motorhomes and say "there's no holes in my roof, and I want to keep it that way" whilst stood under a massive Heki roof light lol
Roofers are full of holes, just sealed that's all
C
Chockswahay
My roof, my rules ;)
JockandRita
11,446
149,840
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Well I have an EBL99 and feed a standard solar controller direct to leisure and a gadget from leisure to engine to top that up.
http://www.ebay.co.uk/itm/SPLIT-CHA...579529?hash=item1c5b768a09:g:9YgAAOxydyxSNBaY
It works for me.
And the same set up works for us too, with our EBL4-105. (y)
The only time we suffered a flat engine battery since adopting this set up some years ago, was when the solar panels were covered in snow and ice for a couple of weeks during a really harsh winter, but that was a one off.
Cheers,
Jock. :)
andy63
4,672
15,017
south shields
None
since 1990
Hi @chockswahay ... you may be sorted now with a solution but I've fitted a few battery master devices to vans ..The type in the link posted by @hilldweller above..
There were no issues with the power management systems fitted in the vans (think they were Sargent control units ). The vans all had solar charging the leisure batteries and allow i think up to a one amp trickle to the start when the leisure voltage reaches a ptedetermined level.....
Ta Andy
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
You have to be careful here
The CBE CSB2 and the battery master work very differently
If you don't have solar the former is useless and you need the battery master
andy63
4,672
15,017
south shields
None
since 1990
hi andy wasn't aware that the devices were that different, I chose the one I mentioned above following a link you gave me at the time... can the difference be explained easily in simple terms or will I have to go and read up myself lol.
ta andy
eddie
8,142
41,174
Taunton Somerset
RV
since 1989
The CBE only starts to transfer charge once 13.6 volts has been detected so if you have no solar that will not happen
Bearing in mind that I designed the Battery Master to overcome problems with quiescent drain over the Winter months rather than Solar transfer which is a happy by product.
People would not use their motorhome, a motorhome built on a commercial chassis designed for Bob the Builder or Flora the Florist to use daily, not have loads of electrical additions installed and left for weeks on end.
Flat engine battery, charged leisure battery! The discharged engine battery at this stage is probably ruined, and jump starting from the leisure battery has probably irreparably damaged the leisure battery. Worse than that, the 20amp fuse either end of the split charge circuit will blow as the effect of placing a discharged engine battery in parallel with a fully charged leisure battery will create a massive electrical imbalance and as sure as eggs are eggs, additional electrical issue will occur
The niggles will potentially carry of dogging the owner for ages after the flat battery episode.
So Battery Master will "share" the quiescent load safely between the two battery types, significantly increasing the length of time the motorhome can be left without issue.
Add an additional external charge to the leisure battery by solar, wind or hook up and so long as all the batteries on the system are in good order, the motorhome can be left indefinitely without any starting issues
C
Chockswahay
It works for me.
Ta Andy
At the risk of being ridiculed .............. could you tell me how exactly I would wire this device in please? My limited understanding of the EBL99 is that all charge/transfer etc is automatic (?).
So if I fit this device instead of solar, then the leisure battery will top up the starter battery (?) until both are flat?
andy63
4,672
15,017
south shields
None
since 1990
No risk of that from me lol
With the device that was linked to earlier there are only 3wires require wiring...
An common negative to both battery banks and a posotive to the leisure and start batteries..
The start battery will only receive a charge when the leisure reach 13.6 volts.. There won't be a flow from start to leisure..
Techno has mentioned the difference between the battery master and the device I'm on about in the posts above
Ta Andy.
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Newbie
I have an easier answer, we have a battery isolator fitted. When I park up for a couple or three weeks, I just switch it on and bingo, no more battery discharge!
KH
