My Slide Out Wont Slide Out- HELP (2 Viewers)
superwhite
6
Our Slide out will not come in or go out smoothly just lately.
We have had to bring it in manually.
Can anybody suggest what might be wrong with it .
It does not work on the electric or the generator
June
:cry:
Thepips
Trade Member
Sep 26, 2007
493
Basingstoke
RV
Could you give us a bit more info? Is it electric or hydraulic? Does it move at all? Any strange noises?
I'm sure we can help
Doug
L
Lindy-C
Is the motor working?
Jim
Ringleader
Jul 19, 2007
36,417
130,895
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I had problems with one of my slides in that they drop slightly over time and then the motor can struggle. Mine has a couple of adjustment nuts on each slide out arm that can lift it a little and this can make a big difference.
S
superwhite
6
Its electric with a manual backup.
It was working perfectley a month ago but over the last few weeks it has struggled more and more.
Now it will not operate on the electrical switch. It will work on the manual hydraulic back up.
The motor is working ok.
Jim may be somewhere near.
The bottom of the slide out is wood panelled and today when moving the slide out back in there were wood shavings to be seen.
I have seen the support beams that Jim is talking about and the bolting assembley. It may be that by lifting the slide out about 5mm that will do it. Its just a case of figuring out how I lift it.
June & Jim
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
When you have figured out what nut does the lifting, may I suggest you don't rely soley on the nut to lift it.
Take the main weight off the mechanism with a blocks of wood and small bottle jack, then adjust nut and lower slide back down.
Expensive damage will be caused to the threads if slide is not supported:thumb:
Geo
S
superwhite
6
Thanks Geo
I will have to take the slide to its extended position to get to the bolting assemblies. Its to late in the day for that, plus I'm to tired.
From memory these bolts are fixed into a slot and when untightend they will move up and down in the slots. Move the slide up or down and then tighten the bolts to adjust the slide elevation.
It may not be so easy to move the slide up, I have a feeling, again from memory that the slide may already be adjusted to its maximum elevation. In any case I wont be trying it until I have time and I'm concentrating properly.
If there is any risk that the slide will drop or damage itself in any way it will be a workshop job.
June & Jim:thumb:
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Just for other peoples information there was a very simple solution to this problem. The steel rams had not been lubricated properley.
Another good tip was to spray the rubber seal around the slide on the inside with back to black. This will stop any resistance when sliding out whilst still maintaining a good seal
Jim :RollEyes:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
So is Superwhite now changing his user name
to SuperCrimson:Blush: or Slick 50 prehaps:ROFLMAO::ROFLMAO::ROFLMAO:
Geo
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Hi Geo,
:Blush:
supercrimson would probabley be the correct name change. So I was wrong. It isnt the first time and it wont be the last. :Doh:
In defence the guy that soughted it went straight to the cause of the problem and said that it a common fault that he was asked to repair so maybe this will help others with the same problem.:Smile:
I cant be the only stupid person on the planet (or can I) He could have told me all manner of things however he did the right thing and it cost me virtually nothing. :RollEyes:
The slide amongst other things was worked upon by Midland in Coventry, they did an excellent job
Superwhite is the missus :winky:
Jim :thumb:
algill
625
213
Derbyshire
Fifth wheel
Just been reading this post with interest as we've recently been thinking about what maintenance we should be doing on the slide out on our fifth wheel.
What should we use to lubricate the rams? Is there a right and wrong product to use?
What else should we be doing, other than the tip about sparying the seal with back to black?
Thanks.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Thanks.
Contact Linda at Stateside Tuning advertised on here, as there is a proper lubricant for the job and believe it or not its called RV Slide Lubricant, failing that any DRY lubricant will do the job ie graphite spray types but you must stress DRY lubricant, do not use any other, oils etc as these will atract dust and grit causing premature wear and or failure of the mechanisms
Geo
Geo
