My roof is going green
Discussion in 'Motorhome Chat' started by DavidG58, Sep 12, 2014.
  1. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
    Bolsover, Derbyshire
    My MH is parked under our bedroom window, every morning when I open the blinds I wish I was away not going to work, but this week especially I also think I can more green algae appearing every day
    Made worse by the white sat dome which really seems to show the green off perfectly
    Ladder and cleaning this weekend I think
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I've used Onedrywash for years David. It leaves a polish on the van which doesn't stop the green stuff but makes removal a lot easier. Presumably other products which leave a similar coating work similarly.
    • Like it Like it x 3
  3. JJ
    JJ Funster
    May 1, 2008
    15,027
    27,037
    Paint the rest of the van green to match...
    JJ :cool:
    • Like it Like it x 8
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Hi David get a spray bottle and fill it with 25% bleach,top up with water-spray on and leave for a hour or so then good rinse off- better still go to a nice pole/check guy who will wash it all off for you for a tenner while you sit back and have a coffee and start WW3 with controversial posts :D
    terry
    • Like it Like it x 5
  5. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
    I pay £8 for them to clean up to the roof line, wouldn't trust them to go on to the roof (y)
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
    Thinking about it, if Chris sells his MH before it needs tyres, I think I might swap mine because it needs a clean :D
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    they don't need to go up there simply reach across from a step ladder at the side :D enjoy the coffee (y)
    • Like it Like it x 1
  8. GJH
    Aug 20, 2007
    27,349
    34,950
    That's what I do. Mind, it is a big stepladder :D
  9. Wombles
    Wombles Funster
    Oct 28, 2013
    2,741
    1,934
    SW England
    We have power lines overhead that whole flocks of birds frequent, neighbours trees that deposit heaps of leaves onto everything & in direct sun so we keep ours covered when not in use. Have had a lot of experience with caravan covers in the past good & bad but now have this http://www.maypole.ltd.uk/Motorhome-Covers_15916 & very good. We wash off the motorhome, spray over with Bobby Dazzler then slide the cover on - even if months later there is no need to clean it again as in same condition when the cover is removed(y) Add a couple of wheel covers & all protected. It is a hassle to put the cover on (really need 2 of you & some brushes/poles to get it on top) but saves on cleaning & reduces ageing so worthwhile for us. In an ideal world we would have a barn to drive it in to & be able to use it whenever we want but not there yet...
  10. movan
    movan Funster Life Member
    Dec 2, 2009
    14,250
    26,124
    Moving around
    David, I read that the besst way to clean a green roof is to park a Burstner T680 alongside your own van and clean both of them together. I will bring it to Lincoln to help you out. :)
    • Like it Like it x 7
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    Have you considered a shotgun?
  12. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    Just for the birds, not the neighbours!
  13. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
    Job done, but never again, anybody who thinks their MH moves a bit when they get in and out, don't get up on top for heavens sake, I came down feeling sea sick and relieved to be back off. The rocking is bad enough, then couple that with standing on a wet soapy surface, jeez, not for me
    These companies offering a full external valet can do it next time
    What I have also found that bolt on wind out awnings are really badly designed, or ours is at least, it creates a trough the full length of the awning 5.5m in our case about 75mm deep, we had seeds, moss and various other bits of vegetation in various states of decay and new things growing in the 'compost' :Eeek:
    Must remember to sell it before it gets that bad again (y)
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Hi David stuff some pipe lagging foam in the gap ;)(y)That will stop all the crap going in there :D
    terry
  15. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,860
    4,315
    Newbury , West Berkshire
    I believe that fiamma sell a strip that fits along that gap ,i have one on my MH awning.
  16. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,421
    5,449
    East Sussex 01-580-881288
  17. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
  18. wiljoy
    wiljoy Funster
    May 23, 2008
    919
    999
    Crook, Durham
    Also use the One Car wash for the roof and it has served me well for over 10 years now. Hasn't worked on my hairless head though.
  19. GJH
    Aug 20, 2007
    27,349
    34,950
    I'm surprised you have such a problem David. Must be the way the awning was fitted. Our van has an Omnistor and there is nowhere near such a trough. I ran a bead of sealant along it to guard against any water penetration through the bolt holes but it is only a normal (few mm) bead size.
  20. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,218
    14,192
    I am not impressed either Graham, quite a surprise when I found it
    [​IMG]
    this example shows something like what we have, but our casing is not so rounded, creating a deeper 'channel', not sure if it has been fitted too high, but too late now to change it I reckon
    Lincoln show maybe time to change, but maybe 5.5m of this capping is a better financial option :D
