My Hymer Goes To Hospital (1 Viewer)
JJ
Mágica
May 1, 2008
19,253
47,965
Burstner Privilege T
over 50 years
After putting off the job for years, I finally arrange for the van to have a lung transplant (new vacuum pump).
Monday 10.45.
Parked in waiting room for the surgeon (Dr Micha) to finish with his current patient.
The replacement lung is ready...
Being a village garage, not only is it a repair shop, but also a bit of a community centre. People drop in from time to time to pass the time of day and indulge in witty banter. (There used to be a similar one in Sennybridge. They had biscuits though.)
I am hoping the driving cam for the pump isn't too worn. Had I known about it, I would have bought one just in case. Won't know until the patient is on the operating table and opened up.
Taking this opportunity, whilst waiting, of doing a bit of cleaning and tidying inside...
JJ :cool:
JJ
JJ
Mágica
May 1, 2008
19,253
47,965
over 50 years
11.30...
Dr Micha makes a start.
First job... bonnet off, radiator out.
Other patients have arrived... no doubt the surgeon's time will be split between different operations.
JJ :cool:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
You do realise this is not covered by your E111, don't you.
It could be quite painful.
JJ
JJ
Mágica
May 1, 2008
19,253
47,965
over 50 years
1.30... back from lunch.
1.45... pump off.
Problem...
As suspected, not only is the vacuum pump cam a tad worn but the disc that drives it is completely worn out.
Why they don't sell a new driving cam disc thingy with the new pump I don't know!
Anyhow, one of the gang has gone off to try to find/get a replacement (hence no photo of it...)
Fingers crossed.
If we have to order one I am told it will take five days!
So I might have to live here for a while!
And there is a possibility of a VIP Funster visiting QMJ on Wednesday.
The really pleasing thing is that the range of faults that I have been experiencing over the months, and which have slowly got worse and worse, are down to this wear.
Being a super Mercedes, the vacuum generated by the pump is used for several, different things.
It assists the automatic gear changes and kick down pedal.
It works the brake servo AND it operates the diesel cut off valve to stop the engine when the ignition key is turned off.
It will like driving a new motorhome if/when I get all these items working properly again.
JJ :cool:
4,270
7,338
Oxford
WildAx Constellation
Since 2008
Good luck!
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
[QUOTE="JJ, post: 2039685, member: 2459"
JJ :cool:[/QUOTE]
That means that you will be able to go on proper campsites without fearing embarrassment as it bangs and farts and generally frightens people.
No more parking behind the brickworks hoping the machinery will mask the noise.
glastry
395
357
northern ireland and portugal
a class s550
JJ, with proper vacuum restored,the gearbox may need adjusted back to its original position!
it was set at 2 and a quarter turns anti -clockways.
good luck.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Pleased to see you are back on the road so soon. I wonder if it was this that caused your brake issues in France?
bobandjanie
8,159
15,788
Javea, Spain
Pilote V600g
Does this vacuum pump do your wipers JJ, ;) had an old Ford prefect take your foot off and give it a quick wipe. :LOL:
They will make sure you will soon be on your way, :D having you using all their water and electric. :eek: Bob.
JJ
JJ
Mágica
May 1, 2008
19,253
47,965
over 50 years
5.00(ish)
Job finished.
The Mega Boss even helped putting the 'bonnet' back on...
Test drive to the Supermarket... nearly lost everything off my table and all the washing up water when I first just touched the brake pedal... YIPPPPPPEEEEE.
The brakes are superb... the kickdown works better... gear changes are smooth but maybe need a slight adjustment now (see Mr Glastry's post above) and, joy of joy, the engine actually stops immediately I turn the key off.
Price for supplying second hand cam thingy, new radiator water (green) and fitting it was all...
€80.
JJ :cool:
Zepp
1,673
3,260
Roaming
7 Years
Glad its all sorted and fixed and what a good price JJ
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Bloody hell..... 80 euros.....
Wish I was a freeloading night of the road tosspot, with bolted lettuce coming out of my earholes... :giggler:
Good one @JJ..... (y):*
JJ
JJ
Mágica
May 1, 2008
19,253
47,965
over 50 years
I remember those wipers well... my first car was a 100E Ford Escort...
The Hymer has electric wipers... not that I need them very often these days.
JJ :cool:
