My engine is vibrating and shaking van, only happens on Motorways (1 Viewer)
Robert Small
5
Winchcombe
Autotrail Scout
I have an Fiat Autotrail 2.8 D, W reg. Over last few years I have been getting a vibration that appears to be coming from the engine but shakes the whole Van. It only occurs on Motorways and used to happen rarely and not for very long, this summer we did 3,000 miles but had no trouble until we hit the M20 around Ashford and lasted 20 miles then stopped. The last three times I've used it it has lasted longer until it lasted almost all the time from Exeter to Tewksbury but stopped as soon as I got off the motorway and even at the same speeds 50/55 did not start again. At first ,in Germany, I thought it was the road surface and again in England but I asked my mechanic when he put a new gearbox in to check the engine mountings, fine. Any ideas, is it the drive shaft? is it just an old van, my mechanic doesn't seem to know except he feels the Van has years left in her. Please help.
cronkle
111
47
shropshire
c class
since1995
You've probably already thought of this but are the wheel nuts tightened up?
R
Robert Small
5
Winchcombe
Autotrail Scout
Thanks for the reply but they are okay, checked during the last MOT
Frentchy
589
2,282
Bordeaux France
Elnagh Baron Profiie
since late seventies
It could be Wheel Balance coupled with weak shockers, Is it more prominent on one side?
TheBig1
17,575
42,950
i seriously hope youre not implying you dont regularly check road wheels and tyres, leaving it to a yearly MOT
sounds like distorted tyres to me.....gets worse as tyres heat up on the motorway. tyres need replacing every 5-7 years regardless of tread
icantremember
8,325
17,534
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Some of the M20 in that area is old concrete instead of tarmac and I think everyones vehicle vibrates along there .. I know mine does!
Another possibility is worn engine mounts.
R
Robert Small
5
Winchcombe
Autotrail Scout
Not as I have noticed. But I can get someone to look at them. Thanks
Had a recent MOT. But will get the tyres checked Thanks.
R
Robert Small
5
Winchcombe
Autotrail Scout
According a mechanic they were okay when he replaced the gear box.
Nov 6, 2013
1,414
3,155
S. Ayrshire
The usual
Since the beginning
Had the same on a car once. Was moisture inside one of the tyres. Took it back to the tyre fitters - removed tyre, cleaned and refitted. Sorted the problem.
Billy23
1,610
2,984
On a planet...far, ....far away.
On and off 1995
I am not a mechanic but I seem to remember, way back, like 40 years that you would get a similar problem if the prop shaft or drive shaft from the gear box was running out of balance. I notice that the gear box has been changed, did he put it back in the same position? I seem to remember if you turned it just one hole it was not running "true".
As I say, that is.....way back thinking, so forgive me if it is wrong.(y)
RS_rob
1,010
669
Turnford
over a Year Yay................
Is it on accelerating only ?
If so it's the n/s drive shaft
I have the same problem but can't find the correct drive shaft.
Mar 29, 2011
961
639
Rugby UK
C Class RS
A while ago I had a problem with a Vito, the tyre place told me it was a vehicle problem took it to the merc dealer and he said straight way it was a distorted tyre, back to the tyre place and it was, new tyre and problem solved, a couple of years ago it happened on our VW T5 as well, they say that Michelins & Continentals are the worst for it and yes I have had one of each, Michelin contributed half the cost on to new ones on the VW.
Dave
MikeD
3,936
3,697
London
IH PVC
Since 2012
If you have had a new gear box I would check either prop shaft or drive shafts. (y)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
In some vehicles there may be a "balance" fitted to the drive shaft to the wheels.........one side usually longer than the other.......check that this "balance" isn't free and is clamped in the correct position.
Hope you find a solution soon.
TerryL
6,165
8,166
North East
Low Profile
I'd go with the distorted tyre - had this happen to me twice on 2 different cars. Replaced tyres, problem went away.
You probably only notice it on motorways as they are generally much smoother than ordinary roads and any vibration is more apparent.
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Would be interested in the diagnosis when you find out what the problem was. I had a works Citroen Relay that used to have similar symptoms it would vibrate violently with the feeling of something to do with driveshafts.....we would stop...... then carry on with no problems. It only happened two or three times in a 139,000 miles.
43,286
49,201
you'll be lucky......the op became a read only member at 3.26pm yesterday......no more free posts.
Badknee
7,406
411,370
notloB
Vantage Neo
Living the dream.
I would get the front wheels balanced. That would show up a distorted tyre, damaged wheel or just out of balance.
TheBig1
17,575
42,950
far too many people just presume that if a vehicle passes an MOT once a year it cant have any mechanical defects. loads of things can easily slip through the MOT inspection and to be blunt the driver is responsible for the roadworthiness of the vehicle on all journeys. I know some people rarely even check tyre pressures and fluid levels if ever. then they are surprised when they break down
Apr 28, 2013
3,682
80,631
Alentejo,Portugal
Hymer A Class
Since the '80,s
Dave
Quite right,I was in my local garage here and in trundled the Michelin truck,the boss who unloaded it took one one and threw it to one side and said to me "take a look" I was amazed to see it was nowhere near round!!
Must be a quality control problem but this one was miles out.
I have put Conti's on the back of mine recently and luckily at the moment they seem fine.
iceni
300
117
Birmingham
Lowline Coachbuilt
27yrs
if it comes and goes it sounds like the drive shafts
For good prices on drive shafts try JR driveshafts in brum 0121 242 820
i think they will post out
Dec 12, 2010
5,396
21,439
Cumbria
since 2011
If you put the palms of your hands flat against the tread then the sidewalls of the tyres and slide them lightly over the surfaces, you can often feel flat spots or out of rounds on your tyres that your eye doesnt see.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
You are quite right.
The MoT test does not include wheel nut tightness checks other than a wiggle to see if the wheels fall off, and a visual for loose nuts.
G
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
If you asked for the wheel nuts to be checked then yes, but they won't be checked as part of the MOT........
.......sorry Geo, should have read on further.........Griff
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
The big problem with all the Fiat engine configurations was the engine mounts. They are made using the 'metalastic' process, where the steel is bonded to the rubber. This can become 'unbonded' after time, or quicker if there is any oil contamination, causing the engine itself to drop slightly. This can become a source of vibration, only noticed at constant speed and over a distance.
Open the bonnet with the vehicle on a flat(ish) surface. Does the engine block look 'canted' to one side or the other?? Hold the rocker cover with both hands. Can you 'rock' the engine back and forwards?? If 'yes' to one or both tests, get your mountings checked/changed.
Jan 28, 2008
10,111
18,303
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
best way to check engine mounts is to have someone lift the clutch while you look at the engine
