My DIY SOG for under a tenner.
Discussion in 'Tech/Mech General' started by LaMB, Apr 14, 2015.
  1. LaMB
    LaMB Read Only Funster
    Jun 15, 2012
    69
    49
    Boston
    • Like it Like it x 1
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,415
    5,669
    Guisborough
    I went to the fish tank shop for an activated charcoal filter to cut up instead of the proper SOG thing and that was about £8 granted I might get two out if i'm lucky.
    looks like you have done a nice job.
  3. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,994
    11,237
    Glasgow
    I need some step by step instructions to go beside each photo for me to follow this. Not too technically minded.
  4. ABZSteve
    ABZSteve Funster
    Jan 8, 2014
    797
    870
    Not here
    Do the replaceable filters do the same thing?
  5. gillnphil
    gillnphil Funster
    Apr 12, 2010
    954
    4,429
    West Suffolk
    Good piece of innovation. Certainly not " bog standard" work.
    Phil
    • Like it Like it x 3
  6. LaMB
    Jun 15, 2012
    69
    49
    Boston
    I'll see what I can do, but it might be next week as we are off to Peterborough show tomorrow. However if you aren't technically minded, you probably will not have a hole saw to cut the big hole.
    I soldered the wires in as well, and used a stiff bit of wire as a 'fish wire' to route the wires from the fan, underneath the casing to the side for connection.
  7. LaMB
    Jun 15, 2012
    69
    49
    Boston
    I'm not sure about the whole filter thing anyway. I nearly didn't bother with one at all. I think the 'proper ones' are activated charcoal and so I bought a piece of activated charcoal mat off ebay. It is enough to cut out 6 pieces, but as it is only 1/2" thick, I used two pieces, leaving me another two changes of double thickness, should I ever change it!
    Maybe someone else will know what the filter effect is.
    Martin
  8. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    Proper job.
    You got lucky with that built in motor housing.
    I know SOG kits look expensive but everything fits beautifully and real quality plastic that looks made to last.
  9. Sidney
    Sidney Funster
    Jan 27, 2013
    1,259
    824
    Stamford
    I have the same Khazi as you. The SOG kit (type F) for this WC is quite rudimentary and makes no use of the housing designed to accommodate the fan and alike.
    [​IMG]
    The Thetford kit on the other hand is quite extensive and changes the top control PCB which allows you to manually switch the fan on or off (as well as automatically switching on for a timed period when you use the flush) and reed (level indicator) as well. No flexible pipes, no messing about when you empty the thunderbox...
    [​IMG]
    I think you solution is better that the SOG
  10. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    Surely this is not the same? A SOG draws air through the cassette but yours looks like it just draws air through the cassette locker?
  11. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    Great if you are constipated.
    • Like it Like it x 5
  12. scotjimland
    Jul 25, 2007
    28,940
    25,630
    that's what I thought, but wasn't sure how the OPs worked.. ..
  13. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,961
    12,252
    Plympton, Devon
    I would comment if I could see the OP's pictures!
    • Like it Like it x 2
  14. ivorantony
    ivorantony Funster
    Jan 22, 2013
    514
    548
    London SE
    On my C250 that has a similar set up, the fan draws air from the cassette when switched on at the control panel, there is a non return valve in the top of the cassette that allows air into the cassette,
    I improved my air throughput by adding an additional fan lower down in the outlet that comes on automatically by triggering a PIR as you enter the WC,
  15. Techno
    Jul 28, 2010
    14,189
    15,163
    If the cassette seal is tight against the toilet bowl then it won't take the smell away at all and the contents won't break down faster like it does when fresh air is drawn through.
  16. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,725
    14,495
    Scottish Borders
    If you need a hole saw we have one you can use Sandra...... means you will have to come to us for a weekend though :)
  17. LaMB
    Jun 15, 2012
    69
    49
    Boston
    No, the cassette has a vent which goes down to the bottom where the rubber ring is shown in the picture. Air is drawn down into the cassette and down through the filter and fan underneath the floor, but only when the blade is opened, thus not allowing 'foul' air inside the toilet compartment. The vent in the cassette is quite clever and only opens when it is inserted in the compartment. If you look at the underneath of the cassette you will see it, (if your cassette is the same as mine). I think it needs the vent so that it doesn't blow up due to expansion, probably of gasses. lol
    Martin
  18. LaMB
    Jun 15, 2012
    69
    49
    Boston
    I looked at the Thetford way, but apart from it being expensive, I think you have to switch it on automatically, which I didn't want. I know some people have done a similar mod to me but use a switch, which again I didn't want.
    If you sign up to dropbox (it's free), then you can see the pictures. I think it would be a big job to upload them all here. Sorry.
    Martin
  19. Sidney
    Sidney Funster
    Jan 27, 2013
    1,259
    824
    Stamford
    On the C260 there is a tube that goes from the bottom of the cassette to the vent on the top. When the cassette is inserted into the housing it opens the vent. The fan in the base of the housing draws air from the cassette and fresh air goes in via the vent.
    The Thetford version switches the fan on when you operate the flush. It then runs for a timed period and switches off. You can switch it off earlier by pressing the button.
    Equally you can put the fan on, do what ever suits your mood, and then flush and the fan switches off after a timed period or you can switch it off manually.
    The foam ring you can see in the OP images ensures a good seal between the tube and the fan housing. A replaceable filter sits on top of the fan. I plan to cut this open and put in some new activated charcoal rather than buy a new one every six weeks!
  20. Sidney
    Sidney Funster
    Jan 27, 2013
    1,259
    824
    Stamford
    Either way the OP solution is far better than the SOG which costs MORE than Thetford's own solution.
