My Bleeping steps
Discussion in 'Motorhome Chat' started by RobGriff, Oct 31, 2012.
  1. RobGriff
    RobGriff Funster
    Aug 2, 2010
    114
    84
    TONYPANDY Rhondda Wales
    Hi everybody hope you are all well, I've have a CI Motorhome(2004) when we are traveling there is a high bleeping sound coming from the step switch. The only way I can stop the bleeping is to take the fuse out . When we are parked up and the steps are down the steps tend too go back in a little way after a short while and you have to press the switch too put the steps back out. thanks Robert ( PS The beeping is driving the wife mad ). :Sad: :Sad:
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    sounds like dirty switches or a seizing mechanism
    some steps are wired to retract automatically when the ignition is switched on.
    there will no doubt be switches on the step that control the step alarm and stop it when in and out these could be faulty or dirty.
    if the mechanism is seizing there will be a resistance which could be causing the step to creep back in and out when in causing the alarm to go off.
    a clean and lubricate could work wonders.
  3. RobGriff
    RobGriff Funster
    Aug 2, 2010
    114
    84
    Hi Andy will give the steps a good service and check the switch and give it a clean. Robert
  4. hilldweller
    Dec 5, 2008
    27,312
    26,301
    Macclesfield
    Tell her she now knows what it's like to be a man !
    Steps - they keep cropping up, it looks like they are a £1000 problem but they are prepared to spend only £100 on them. Result, pain in the bum for the owners.
  5. RobGriff
    RobGriff Funster
    Aug 2, 2010
    114
    84
    Hi Brian thanks for the information will give the steps a good service on the week end
  6. hilldweller
    Dec 5, 2008
    27,312
    26,301
    Macclesfield
    Good move. They get covered in crap and get no service. They fail. The surprise is they don't fail sooner.
    If you search on TEETH you'll find a thread where one of our proper job engineers here built up new teeth by welding to rescue a step. That impressed me.
    The first thing I'd do is remove any micro switches and replace with proximity sensors but that's £1 against £25 but they would be good for life. Motors and gears, junk those and replace with hydraulics. There's your £1000 gone.
  7. tofo
    tofo Funster
    Oct 1, 2007
    6,647
    6,428
    Kirby cross further from londin
    Give the runners a good hosing before you get it checked
    all the muck builds up stops them retracting fully
    :thumb::thumb::thumb:
  8. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,619
    22,803
    Narrfoook
    If your steps are the same make as ours, the darned switch mounting point is set back too far ( by about 2 mm ! )
    From new, they had put a bit of rubber on the tang that stuck out to activate the switch.
    As time went by the rubber bit slowly compressed
    I have replaced it but can see a time in the future when it will cause grief again
    next time it need doing I am going to drill the tab and tap the hole so I can put a screw in it and adjust as needed
