Musty smell in new MH (1 Viewer)
Ken&Carol
28
16
Preston
Van conversion
Newbie
Hope someone can solve this mystery!!!!! MH only a couple of months old we have been out a few times including a week away recently. The MH is cleaned everytime we get home.
We have noticed a musty sort of smell when we go into it and we are unsure of why or where this is coming from, has anyone any ideas?
The only thing we can possibly think of is, is the smell coming up through the sink from the waste water tank? This is always emptied?
I hope someone out there has some ideas.
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Check, or get some one to check for damp...
Not all way`s visible till the problem get`s too bad..
Just for peace of mind..
Ken&Carol
Ken&Carol
28
16
Preston
Van conversion
Newbie
Do you think there could be damp if the vans new, and it's only been used approx 3/4 times?
TheBig1
17,601
43,042
hard to describe what damp smells like, but it is sort of musty and wet wood. just because the van is nearly new doesnt mean its not leaking somewhere.
to rule out waste tank gas circulating n the van put a bottle of cheap cola down each plug hole. if it still smells get it independently damp tested
Derbyshire wanderer
1,285
2,383
Derbyshire
C class
15 years
Try putting the plugs in the sinks and have a sniff round after a couple of days. Hopefully that's all it is.
I am always flushing the tank and still get a nasty niff if the plugs are not fitted.
Strangely it is really noticeable if driving with window down and no plug in.
Zepp
1,673
3,260
Roaming
7 Years
I agree with the above get a damp check done by your dealer
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Possibly.......... I doubt if it is that new the smell was coming from a plughole..
Just to make sure..... stick some tape over the plugholes or put the waste plugs in and make sure they are air tight and leave it over night and see.
Eeyore
362
398
Have you checked the joints of the internal water and waste systems for leaks ? Have you got your carpet wet at any time ? Wet carpets or damp laminate flooring can small musty.
Jim
Ringleader
Jul 19, 2007
36,323
130,298
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Grey waste water really can pong. Chances are, that is the smell. In the US they use Water Softener in the grey waste tank Google "GEO Method" You can buy water softener tablets from the supermarket. I've never used it, but some swear by it and regularly add a tablet to their waste.
DanielFord
3,020
3,086
A motorhome that new should smell like a mixture between new car, and new furniture! A musty smell should rightly ring alarm bells, I'd get it checked ASAP!
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
You might have dropped a BLT or something behind somewhere......Its not the fridge, I take it??
13,054
101,386
Bolsover, Derbyshire
Hymer S800
not long enough
I am with the grey water theory here, we get exactly the same and with windows open when driving it is much worse, I reckon it draws the air back in somehow through the grey tank breather
It is typically much worse for us when just emptied, now we close windows sharpish when leaving rallies, turn on air con, all then OK, but like you there is a niff in the air when opened up, we now keep a couple of air fresheners in the MH and try to remember to push down all plugs (y)
2,248
37,616
Burry Port South Wales
Since 2003
When emptying your grey waste the suction of the tank emptying can remove the water in the sink and shower traps, then allowing the smell into the van through the unprotected drains.
After draining your grey waste, just run the taps or pour some fresh water into the sink or shower drains to re-establish the traps. (y)
TheBig1
17,601
43,042
the majority of vans dont have traps on the sinks and shower tray and some dont even have breather pipes to allow fast draining. Those without a breather rely on the pressure escaping through plug holes. You can demonstrate this by the plug in bathroom sink or shower popping out as you release the plug with a full sink of water
R
Robert Clark
Our Swift Bessacarr used to smell a bit musty when left locked up. I put it down to lack of ventilation and having no proper traps on the sink and shower wastes.
We helped overcome this by putting 100ml of Fenwicks drain and tank cleaner down the wastes every couple of days, when using the van. And by keeping the windows slightly open on their 'vent' position when weather allowed.
Seemed to help
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
As already said a new van should smell of new furniture, wood, plastics etc. If it smells damp and musty, it shouldn't. If you can smell drains, you shouldn't. If it has no traps and you have to put in plugs, that's very poor. Whatever, back to the dealer, toot sweet.
Eeyore
362
398
Festering grey water doesn't smell " musty"; it smells of drains.
"Musty" is damp, either from the van insulation or from soft furnishings or flooring that has been wet at some point. Take up some carpet, feel under the floor ( spongy ?) look around the areas that have rubber seals joining them to the van body ( windows, external locker doors, roof vents, ventilation grilles etc). These are the places where a small section of faulty rubber seal will allow water to get in.
Badknee
7,407
412,035
notloB
Vantage Neo
Living the dream.
After emptying grey waste tank I always put cheap cola down the drains and we don't have a problem. ...........
Mind you leaving the grey waste valve open all the time helps too ............:wink:
:reel:
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Newbie
This is because the open window creates a negative pressure inside the vehicle and it will then draw in air from anywhere it can. In the case mentioned it is drawing air through the plugs and the waste tank.
I agree with Eyore, drains smell of...well, drains! Musty will most likely be damp. Get back to the dealer post haste and get it checked for water ingress.
KH
Daveo2006
1,164
998
kent
Apache 700
3 years
The kitchen sink and whb on our new autotrail are very slow running when level or the front of the van is lower and we had a vile smell in the bathroom last weekend which flooded into the van when you opened the door.When we left site and emptied the grey tank i put some cleaner down the wastes and ran the remainder of the fresh water through as well. After reading this thread i went out to the van and this seems to have cured it. I just traced the route of the waste pipes and they are sat on the top of the grey waste tank before entering creating a bit of a trap . I lifted it and there was water sat in there which could well be the problem. It may well be if the waste pipes were shortened it may well solve it. Theres no room to drop the tanks under there without it being very awkward so needs to be over a pit really. Im sure my dealer will take a look at it for me.
Derbyshire wanderer
1,285
2,383
Derbyshire
C class
15 years
KH
Thanks, that makes sense as the waste tank is vented so it must have drawn through the tank. Always keep the plugs in now and no nasty smells.
musson
487
165
grantham
low profile
since Jan 2014
We put some non bio wash powder in the waste tank, did all the plug holes flushed it into tank, left the tank with some water in on the way home,empty tank at home,see what its like then (some people use cheap coca cola)
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
OP has a panel van so damp not unheard of but reasonably rare? smelly waste tanks is a normal thing to have to deal with but a different kind of smell to damp?
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
I had a niff in my lunar. Emptied and flushed the waste tank and then left the waste tap open to get some air in.sorted it.
Also noticed if you use the shower and don't drain the water out the shower head it can stagnate. ..
Make sure the toilets emptied after use if your popping the van in storage. ..
Was trial and error but basically get in the habit of draining the water system if it's being parked up for any period of time unused.
Finally, it could be a leak like others have said.
